Old 12-27-2010   #1
hiperf406
hiperf406's Avatar
Default Oil leak
I have a oil leak on the passengers side of my 91 ZR1, when I start my car there is a oil burning smell. The car sat for 6 mo & there is a fair puddle under the car. I don't know if the cam covers have a gasket in them or not, if so is it a big job to replace .TIA.
lorne #1748
lorne # 1748
Stock except for a modified Corsa exhaust.
When the flag drops the bull sh1t stops!
hiperf406 is offline   Reply With Quote
Old 12-27-2010   #2
sammy
Default Re: Oil leak
other things it could be is the oil pressure switch,either the top one or the one thats a pia to get to on the bottem side of the oil filter housing or the oil filter housing gasket itself as well as the lines to the oil cooler . you need to take your time with a good light and you should find it .oh one other common area is the oil pan bolts have a tendancy to be loose .hope this helps
Old 12-27-2010   #3
ScottZ95ZR1
ScottZ95ZR1's Avatar
I'd suggest starting with a check of your exhaust manifold studs Lorne.
A common issue with a simple fix - check item #20 here: http://www.zr1netregistry.com/ZR1_issues.htm#20
ScottZ95ZR1 is offline   Reply With Quote
Old 12-27-2010   #4
tccrab
tccrab's Avatar
My bet is on the Oil Cooler Hoses.
Check where the metal portion is crimped to the rubber part of the hoses.
If your finger comes away wet, there's your smoking gun.
TomC
'Crabs
Old 12-27-2010   #5
TomC
'Crabs
this
Old 12-28-2010   #6
Jim Nolan
Sounds like oil cooler hoses to me. I had the exact problem. Good luck changing them. I don't there is any way you can change those without making a mess, no matter how many rags you use.
Old 12-28-2010   #7
flyin ryan
flyin ryan's Avatar
True story...
Old 12-28-2010   #8
hiperf406
hiperf406's Avatar
Thanks everybody I'll check the oil cooler lines first. Are the lines available from GM or does someone sell hem on the forum. lorne #1748
lorne # 1748
Old 12-28-2010   #9
ScottZ95ZR1
NLA at GM but Jerry has them: http://jerrysgaskets.com/store2/root...b684ee0e812e25
Old 12-28-2010   #10
hiperf406
hiperf406's Avatar
Checked cooler lines & filter neither show any sign of oil leaking. Will check oil pressure senders as I have noticed my oil pressure bouncing around. lorne
lorne # 1748
