Old 05-09-2011   #1
Alberta_ZR1
Default Samco coolant hose question
For those of you that have replaced the lower coolant hose that comes off the water pump, did you install the spring from the OEM hose into the new Samco hose?
Just curious...
Alberta_ZR1 is offline   Reply With Quote
Old 05-09-2011   #2
bobbyhi
bobbyhi's Avatar
Default Re: Samco coolant hose question
I did not install the spring on mine. Didn't seem to need to.
Old 05-09-2011   #3
Alberta_ZR1
Thanks.
That's what I was thinking too, but I wanted to see if anyone else did.
Thanks again,
Old 05-09-2011   #4
Hammer
Hammer's Avatar
Talking Re: Samco coolant hose question
I also did not install the spring, but I did install the nylon cover from the original hose. I used zip ties at both ends of the cover to keep it in place. I've replaced hoses on two ZR-1's this same way.
Old 05-09-2011   #5
Hammer
Hammer's Avatar
PS, use a little die-electric grease inside the hoses. They will slip right on that way and your life will be much easier.
Old 05-10-2011   #6
Alberta_ZR1
That's a good suggestion.
I left them in the sun for about an hour or so and they slid right on with next to no troubles.
Old 05-10-2011   #7
No spring
Old 05-10-2011   #8
Blue Flame Restorations
I tried to bid on a NOS set of radiator hoses today on the bay. I bid $206.00 and the whole set went for a crazy $360.00!!!! Is this typical???
Sorry, not trying to hijack your thread but I'm still in shock!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-10-2011   #9
Common due to NOS competition
Old 05-10-2011   #10
xlr8nflorida
xlr8nflorida's Avatar
That and I have not seen a full set in a box with clamps in about 2 years.
