View Poll Results: Which Performance Chip do you have?
Corvette Consultant 5 1.68%
Doug Rippie Motors(DRM) 53 17.79%
Ebert's Engine Service (EES) 3 1.01%
Formato's FasterPROMs 0 0%
Jeal 4 1.34%
Leonhardt Automotive 1 0.34%
Marc Haibeck 182 61.07%
Marc Randolph 11 3.69%
Southern Georgia Corvette (SGC) 12 4.03%
Todd Pepmeier 4 1.34%
TPIS 0 0%
Vette Doctor 0 0%
Z-Industries 7 2.35%
Team ZR-1 3 1.01%
Corey Henderson (DynoTex Racing) 13 4.36%
Voters: 298. You may not vote on this poll
Old 11-07-2006   #51
Z Factor
Z Factor's Avatar
Lightbulb Re: Which Performance Chip do you have?
Originally Posted by carnold
Sent SGC an email and talked to Aaron on the phone. He asked me to call back on Monday a week ago and got an answering machine. He never returned my call so I guess he is to busy to help so I will look elsewhere. Thanks. Do you have a web site or phone number of the other 2 so I can just call or email and order a chip?
You must have caught him during a very busy time because I personally know him to be willing to spend great deals of his time talking and answering questions for ZR-1 owners, even if he will not be seeing the work. I do know he is less likely to respond to emails, so try giving him another call before throwing in the towel. Just let him know what happened and he will take some time with you.
As to the two mentioned earlier, here are their websites.
http://www.dougrippie.com/
http://www.zr1specialist.com/index.htm
Old 11-07-2006   #52
40th#381
Wink Re: Which Performance Chip do you have?
p
40th#381 is offline   Reply With Quote
Old 11-08-2006   #53
carnold
Default Re: Which Performance Chip do you have?
I am sure he was just busy because he has an excellent reputation. I will try again down the road.
carnold is offline   Reply With Quote
Old 11-12-2006   #54
blackjack
for a completely stock engine,the gm improved chip is hard to beat,and the cheapest...i bought mine for under 100 dollars cdn,and the car runs much better with it...jmo,anyway
blackjack
blackjack is offline   Reply With Quote
Old 11-12-2006   #55
carnold
But will the stock chip solve the 1st. gear to 4th problem? What is a good source?
Old 11-13-2006   #56
blackjack
yes,it does cancel the 1-4 shift idiocy,and lowers underhood temperature,resulting in slightly more power..it also improves the idle quality...any gm dealer should be able to order it for you...i dont know the part number,but the description should say AYBK,or something similar,and was part of a service bulletin issued from gm,for customers complaining about bad idle and lack of power when hot..im no zr-1 guru,but it did make my car happy
blackjack
sent from my black dial telephone !!
Old 11-13-2006   #57
Tyler Townsley
blackjack
No stock chips disable the 1 4 shift pattern, its a epa thing. To my knowledge they do not change the temp on for fans in this calibration, it does address the other problems noted.
The only way to address the 1 4 thing is to disconnect the wires from the sensor or have a tuner disable it in the calibration, same with the fan on temps.
Tyler
Old 11-13-2006   #58
blackjack
i bought this improved calibration after reading mark haybeck`s site...my car`s 1-4 shift was disabled after installing the new calibration.as mark said it would..you can read the results on mark`s site under calibration for 1990..imo,its the best bang for the buck,for a stocker....mark also said 10%more torque because of more consistent underhood temperature,although i never mentionned the fans...jmo,anyway
blackjack
Old 11-13-2006   #59
carnold
I was planning on buying Mark's chip. Is there anything to do other than opening the ECM and changing chips?
Old 11-13-2006   #60
Peaven
Peaven's Avatar
No....it's very easy. Here's a link to Mark's presentation on the subject from his website....good luck.
http://www.zr1specialist.com/HAT%20W...librations.pdf
Peaven is offline   Reply With Quote
