#11 | |
MAP v RPM cells as possible. Finally, I might notice some things about a tune a novice would not while driving. That isn't available remotely. Even if the motor is stock, each motor will have its own characteristics. As an example a stock motor w different gears or aluminum flywheel has a different optimal tune. When you tune your own, close isn't good enough. |
#12 |
So is it safe to say that the ostrich is the way to go?
Do you know if we need a certain socket? Last edited by 1990 quasar blue; 03-27-2012 at 12:18 PM. |
#13 |
#14 |
Thanks again. I appreciate your time.
