![]() Join Date: Jan 2007
Hey Everyone I have been working with Doug Rippie Motorsports (DRM) for a group purchase on the coilover suspension. The DRM coilover set up gives the C4 Race car-level handling, adjustable ride height, and a more controlled ride. The coilover suspension allows each corner of the Corvette’s suspension to react independently by eliminating the leaf springs completely. The DRM coilover suspension can be installed using existing stock shock absorbers or new Bilstein shocks. The group purchase will be for the FX3 or non-FX3 kit without shocks. Other shops sell similar set ups ranging from 2300 as high as 5000. The DRM price for this purchase is 800 shipping included. Here is what you will get:
Four (4) Hyperco coil springs, four (4) billet aluminum top hats, four (4) adjustable sleeves, spanner wrench and polyurethane shock mount bushings. (Shocks not included) ![]() Also DRM has offered the trailing arm and camber brackets at a significant discount. The trailing Brackets 70.00 shipped and the camber brackets at 80.00 shipped. ![]() ![]() Please let me know if you are interested this is a onetime only deal and we must have all orders placed by July 27th. Please let me know if you have any questions! Also our very own Carter (Carter200) makes a very trick set up for the coilover that will allow you to install the coilovers in much less time and best of all keep from all the cutting that was required before. He sells the front sway bar relocation brackets and the rear shock mounting brackets. Very minimum modification to the car is required if using these brackets. Please contact Carter directly if you are interested in the brackets (I would strongly recommend them). Cheers, Daniel |
Daniel
Wow this is a super deal!! I want trailing arm and camber brackets. How much are Carter's pieces? (front / rear) Show a picture Carter so people can see your work! ![]() David |
![]() Join Date: Feb 2011
The trailing arm brackets do work- takes some front end dive out of the car and helps keep the rear brakes from locking up around corners if you find yourself applying brakes in one.
slightly firmer road feel on the rear is the side effect. I will probably never change back to stock- most people would like these brackets IMO. |
![]() Join Date: Mar 2004
![]() ![]() Join Date: Aug 2005
Great Deal!
Do you know what the spring rates are? And how are they different FX3 vrs. Non-FX3? Last edited by tf95ZR1; 07-12-2012 at 05:42 PM. Reason: Wanted 2 |
do the stock FX3 shocks require modification / machining to install the coilover kit?
![]() Join Date: Jan 2006
Local shop can groove shocks for ring. Or can send to Bilstein for rebuild and groove.
Only have to notch rear frame opening and use aftermarket front sway bar bushing mount with Carter's excellent stuff. Ted |
I would also be curious as to who is doing the shock mod. If it is Bilstein, I am curious how long they would have the shocks before they would be returned. I have this set up on my race car nad it has worked very well. I have always wanted to install these on my ZR-1. Trying to get these cars to sit right with the longer rear bolts and the wedges up front can be maddening. I seem to remember the brackets Carter manufactured to mount the front sway bar so you can eliminate the grinding and cutting. It has been so long since I installed these I cannot remember what I had to do. I would appreciate if anyone knows how long Bilstein would have the shocks for before they are returned, or if hter is an alternative.
#10 | |||||
You can do just brackets you'll have to get with Carter on the price I do not know what he sells them for. Quote:
You are right the car feels much more planted in the corner and transfers the power with less drama. They are very well worth the money even if you are not doing coilovers. Quote:
Daniel |
