Old 08-09-2012   #21
Default Re: Need Advice: Miss, low rpm stumbling
Originally Posted by EWest View Post
Injectors tested out fine, fuel pumps test ok, but like I said I have not had the chance to test them under load.
do you know what the injectors tested at?
Old 08-09-2012   #22
scottfab
scottfab's Avatar
And I assume you've cleared any codes. But did any get reset?
Scott
Old 08-09-2012   #23
GSJoe
You're getting lots of good advice here from people with lots more mechanical "savvy" than I have, but I need to suggest something you may have already done, and if not, you must do it whether or not it's the cause of your miss issue. Let me explain. Last year my young friend Matt who owns a '91 experienced a similar miss issue. We did just about everything--plugs, coils, wires...tons of other checks. We chased our tails in vain for months. In August at Carlisle, however, Matt talked to the smartest ZR-1 guy who exists in mho, Marc Haibeck. He gave Matt the trick we implemented when we returned home to Charlotte, and the problem went away. Here's what you must do if you haven't done so already. First, take out those old plugs--I don't care if they're new--and throw them away. Get yourself a brand new set of AC plugs of the right heat range and install them. Next--and here's the trick Marc Haibeck gave Matt--get yourself a 3oz can of Permatex Dielectric Grease (item #81153) at any Advance or AutoZone parts store. (I'm sure other versions of dielectric grease will work, but this one dispenses easily from a narrow nozzle because the can is pressurized.) Put the nozzle into each spark plug boot AND COMPLETELY FILL IT with the grease before putting the boot on the new plug and do the same with the remaining seven. OK, why does it work? According to Mark, the extremely high intensity discharge from that ignition system causes air trapped in the spark plug boot to ionize. When it does, the spark then takes an easier path down the outside of the plug rather than through it. If you look at your existing plugs you'll probably see several with a very fine burn line on the insulator where the spark has been tracking. That's why you must replace the plugs again when you do this. As I said, if you've already completely filled those boots with dielectric grease and the problem still exists, I apologize for the verbosity of this post. If you did not, however, do so. It's a must, and even if your problem does not go away it will prevent another common and similar one from occurring. I sincerely hope this helps you.
GSJoe is offline   Reply With Quote
Old 02-24-2013   #24
Funracer
Never heard of this before but I too am chasing a stumble and am willing to try this to see if it helps. Anyone else tried it or know if it works?
Funracer is offline   Reply With Quote
Old 02-24-2013   #25
scottfab
scottfab's Avatar
I've never heard of this causing a stumble either.
A simple one to try is cleaning the IAC and the tunnel it sits in.
Two screws and you can inspect it for carbon build up.
Scott
Old 02-25-2013   #26
Pete
Pete's Avatar
Just a couple of questions.
What spark plugs you using? hope not any of those pricey crappy plugs just regular resistor plugs work just fine.
Where did you gap them? .035 is best.
Did you buy new injectors or rebuilds?
Injectors can Ohm out good and still be bad.
Did this start after replacing injectors,if so borrow a good set and replace them.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-26-2013   #27
Starman
Starman's Avatar
It will be plugs or injectors. Injectors must have 14 ohms, any less and they are on their way out - replace the entire set when needed - trust me it will save a lot of frustration down the road.
The guys are also right about the plugs, use only the correct AC plugs with the stock coils - fancy, multiprong plugs can cause misses. Always seal your plug boots with dielectic grease.
Good luck
Old 04-09-2013   #28
EWest
I have an update! After trying many of the tests and fixes suggested, cylinders 7 & 4 were still out which obviously took precedent over the stumble. Finally after 4 plenum pulls and countless hours testing everything I could think of, I decided that I would go to a specialist not far from me. From August until late February the only thing I did was a weekly warm up and an occasional sputter around the block.
I was away most of February so the battery completely died at one point. On February 22nd I charged it and fired the engine up, but this time something sounded...different, and by different I meant ALIVE! A quick check of the spark situation revealed that all 8 cylinders were firing! I was dumbfounded.
A test drive revealed there was no miss or stumble and the ability to boil rubber was back. I drive it about twice a week and it is still running well (with the exception of this vacuum leak I have to chase down).
Any thoughts?
Is it possible that after the battery completely died, something reset?
EWest is offline   Reply With Quote
Old 04-09-2013   #29
scottfab
scottfab's Avatar
Yah, that's pretty weird. I've heard of the SES light coming on which indirectly signaled a failing battery but not this.
Unless by clearing all learned block/trim setting and running
off the factory defaults it's masking the failing injector or O2 sensor?
dunno.
Keep an eye on it. Should the stumble come back then disconnect the battery again to see if it disappears again.
Scott
Tags
miss, stumble
