Old 10-18-2013   #21
8cam
Default Re: Water Pump Installation
Originally Posted by WARP TEN View Post
Didn't someone just post in another thread that the bolt sizes noted in the FSM are indicated incorrectly? --Bob
I just pulled my water pump a couple days ago using this diagram, and all the bolts were a perfect match. Made my own drawing to put the bolts on so I know they matched. Will also make it easy to install the new pump.
Old 10-19-2013   #22
rikker
Default Re: new owner 1990 zr1
YES I GOT A NEW RAD,WPUMP ,HOSES,AND THERMOSTAT.
rikker is offline   Reply With Quote
Old 10-19-2013   #23
efnfast
Be careful of your thermostat, there were some bad ones out there.
http://www.zr1specialist.com/HAT%20W...thermostat.htm
Old 10-19-2013   #24
rikker
Got a stat from napa, does the tensioner need to come out and there is a bracket under the altenator does that come out.ALMOST THERE
Old 10-20-2013   #25
8cam
Pulling the tensioner is like a 5-minute job and makes everything else easier to get to. Stand on the passenger side, grab the tensioner and pull towards you. The belt will just about fall off. Then unbolt the tensioner and remove. Enjoy the increased access.
