Old 10-18-2013   #11
efnfast
Default Re: LT-5 Marine engines
So, GM won't release our dyno sheets, but they allowed Mercury to try to sell the LT-5 to others.
Old 10-18-2013   #12
LT-5 came close to being a Bentley engine
Old 10-18-2013   #13
efnfast
That would have been a bummer.
Old 10-18-2013   #14
That was post ZR-1
Old 10-18-2013   #15
Google Mercury 1350 & 1650 race engine's for (what made me think) newer LT5 based Twin Turbo marine engines.
Old 10-19-2013   #16
There was an LT-5 powered boat @ an exotic car dealer in ohio last year. Unsure who made it or who purchased it....
Rick sure has the market cornered on rare LT-5 / mercury items!!!!
Old 10-19-2013   #17
Here are the specs for the 1650. Not too shabby. Twin turbo, requires 112 octance racing fuel. --Bob
1650
SPECIFICATIONS
Crankshaft-rated Horsepower
1650 (1230 kW)
Full Throttle RPM Range
6500-6800
Displacement Liter/CID
9.0/552
Bore (in/mm)
4.57/116
Stroke (in/mm)
4.21/107
Compression Ratio
7.8:1
Cylinders
V-8
Alternator (amp/watt)
105/1481
Controller
PCM distributorless
Fuel System
Sequential Fuel Injection
Fuel Requirements
112 AKI Sunoco Supreme or equivalent race fuel
Transmission
Mercury Racing dry-sump hydraulic
Drive Unit
Dry-sump M8
Gear Ratio
Application dependent (contact Mercury Racing for additional information)
Length (in/mm)
26.69/678
Width (in/mm)
34/864
Height (in/mm)
29/737 (from crankshaft centerline)
Weight (lbs/kg)
1720/782
Warranty
None*
*This product is highly specialized and produced in limited quantities for sale, without warranty, to qualified powerboat racing professionals.
Old 10-19-2013   #18
Here's a picture of its little brother the 1350:
Old 10-19-2013   #19
Mystic ZR-1
Mystic ZR-1's Avatar
Three 1650s (two rights and a left, the middle one running a drive shaft) in a Fountain 39 should be just about right!
FU, do ya think we could lap Long Island in an hour and a half?
Stop for lunch at Montauk?
Old 10-19-2013   #20
69bb
Miss Geico races the 1650 and will be in key west racing against the turbine boat of Qatar. They already raced in clearwater fl with the turbine boat winning with geico spinning out. Check out Super boat racing website.
Thanks Rob
69bb is offline   Reply With Quote
