Old 04-14-2014   #21
Default Re: Broght my new Z home today!
I still think you may have a vacuum leak, my 91 only cycles every 5-8 min. and just gives it a bump. the 93 just for a sec every min & a half.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-14-2014   #22
Racinfan83
I wish mine did that. It is about 5 sec on and 5 off. When I had the car at Haibecks he said it was good though - and I'm not gonna argue with the Master.. lol
Old 04-14-2014   #23
8cam
At least your pump runs. Mine is DOA which means I don't get that priming it's supposed to provide. That's the next item on the list.
Old 04-14-2014   #24
LantanaTX
Ok guys, the engine now runs fantastic! I put a new coil pack in that runs cylinders 2 and 3 and WOW this thing is very quick! Now time to get it registered and some plates on it. The parts store had two types of Borg Warner with lifetime guarantees, a black one that looked stock and a gray one with cooling fins that cost a few bucks more. I went with the more expensive one that said Made in Poland vs, made in Taiwan. I am pretty sure the secondary's are opening as it was frying the tires through the gears.
LantanaTX is offline   Reply With Quote
Old 04-14-2014   #25
Racinfan83
Bingo! Hahahaha!
Fun when it runs right isn't it? I can't imagine how quick some of the modded cars are....
And the other cool part is the gas mileage on the highway. Mine got 25.2 coming back from Chicago at 70+ MPH...
Old 04-14-2014   #26
I'm with Dom , lovin that color
Old 04-14-2014   #27
4-cam
Looks like Colorado lost another Z but it sounds like it found a great owner. Congratulations!
I think the color is awsome. I wish it was offered originally
4-cam is offline   Reply With Quote
Old 04-14-2014   #28
Fully Vetted
Fully Vetted's Avatar
Nice Ride! I picked mine up in Boulder in 2012. That's a fun trip down isn't it. I'm assuming you came through Clayton, NM?
Anyway, you need to join us for the Tx caravan up to Bowling Green next month.
BTW....DO NOT change that color. I bet it even looks better live.
Take care - Let's hook up. I'm only about 45 mins to an hour from you.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 04-14-2014   #29
LantanaTX
Yes came through Clayton NM. It would have been a lot more fun if the engine wasn't running so bad. I am just glad I was easily able to fix it. Now on to the rest of the list of fixes. I don't think I can make Bowling Green as I will be racing in Baja CA.
Old 04-15-2014   #30
Originally Posted by LantanaTX View Post
The bad/to be fixed:
wrong badges on nose and tail
missing the radio
electric seats move with some help
a/c doesn't get cold
drivers side of center console separating from the top plastic trim
misfire when under load
secondary's don't open, vacuum pump runs continuously
plenum was painted yellow then black... a lot of stripping to do.
some of the rubber seals need attention
cruise control doesn't work
intermitant wipers don't work but wipers work otherwise
arm rest latch broken.
missing piece of trim on the targa top where it unbolts on drivers side
Feel free to offer any advice on the issues. Thank you!
Welcome aboard. nice Color just some thoughts.
first as this was never a factory color, who is to say you have the wrong color badges? They look fine to me.
you appear to be missing the rear license plate filler
Check the brake light switchs above the brake pedel if they are not centered the cruise will not set. also you cant set the cruise below 25 MPH.
Everything else in the list is an easy fix. Enjoy your ride.
