Old 11-04-2014   #1
Billy Mild
Default Brakes Failed
The brakes on the corvette failed today. I was coming to a stoplight, the car was slowing down when I pressed the brake pedal a little harder to come to a stop faster. At that time I heard a pop and the brake pedal went all the way to the floor. The car continued to roll forward and would not slow down.
When I lift my foot off the brake the pedal came back to the normal position. I was able to pump the brakes, but they had 0 resistance. The brakes are not effective. Also my BRAKE light is lit up in the gauge cluster all the time now. I haven't torn into the brakes yet, but Brake Fluid reserviors are both full, and I don't see any leaking fluid around the front brake calipers.
I don't really know what to start with if I should look at the pads, or something more serious. Any ideas?
Old 11-05-2014   #2
Default Re: Brakes Failed
Start with Brake Master Cylinder under hood drivers side fire wall. I expect your issue is NOT Brake Calipers or Brake Lines and obviously NOT Brake Pads. Suck the brake fluid out of the Master Cylinder Reservoirs with a Turkey Baster you can get at Target or WalMart before you disconnect the Brake Lines from the Master Cylinder.
If that happens again....grab the Emergency Brake left side of Drivers Seat and pull hard. Keep your thumb on the Emergency Brake Release Button so you can use the Emergency Brake as a Normal Brake.
Old 11-05-2014   #3
I think you lost the brake booster
Old 11-05-2014   #4
efnfast
Keep in mind, when using the emergency brake, it only works the rear brakes. That means you've lost 50% of your braking, and the fronts do most of the work. Don't expect to just give it a light pull to stop the car. Probably something everyone should try in a safe place, like an empty parking lot. Just so you know what to expect when you need to do this.
Why not a thrown pad Cliff?
Old 11-05-2014   #5
I think you would still have some braking but a Hard to push Brake Pedal if it were the Brake Booster.
Never heard of a thrown pad or for that matter some bolts or pins falling out of the Brake Calipers.
I guess anything is possible but then the caliper Plungers would extend and you would probably see a complete failure of the Plunger and brake fluid all over. In any event there would be all kinds of noise I would expect at the suspect Brake Caliper.
If the Brake Pads get sooooo thin as to end up with Pad Rivets on the Rotor.....there would be all kinds of noise at that wheel indicating the Brakes are going to hell in a hand basket
I thought Jerry had Brake Master or Clutch Master Cylinders at one time and maybe Clutch Slave Cylinders on his web site??
Old 11-05-2014   #6
Billy Mild
How will I know for sure that the master cylinder is bad? Anyway to test that? I don't have a jack anymore since my garage got broken into last week. I am going to try to get a jack this weekend and take a look. I will look at the pads first, then move on from there.
If the master cylinder was bad wouldn't the pedal stay on the floor?
If the brake booster went bad, the brakes would just require a lot of effort correct?
Old 11-05-2014   #7
Have you changed the brake fluid?
I agree with Cliff on the brake master...
Old 11-05-2014   #8
My guess I think you blew seals out in the master cylinder or a piston/ rod failure. If it was a line you would have fluid leaking out. A wheel cylinder the others would still work same with a pad failure. The light on the dash no pressure.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-05-2014   #9
mike100
look in the footwell and see if the rear seal area where the brake pedal rod goes into the master cylinder is wet. Otherwise I'd think a rusty line blew out somewhere or one of the rubber lines gave up. you can always look at the ABS unit behind the drivers seat in the storage bin too.
Old 11-05-2014   #10
Mike lists the correct procedure to see if the area is wet below on the brake Master cylinder and the seals are compromised. I mentioned the booster as a POP was mentioned and both reservoirs were full. I have never heard a master cylinder pop but certainly fail with the pedal immediately hitting the floor. It's clearly either one or the other and I agree with Mike if the pedal arm etc is wet. I have seen two boosters fail in my life time and a loud POP was the first indication of trouble
