Old 12-24-2015   #1
Default New LT-5 Wiring Harness...Restomod
Got this with an engine I bought. Was supposed to be for a 32 Coupe getting an LT-5
Seems to have everything and is labeled; including DIS 14 pin.
$400 OBO, nice piece
Old 12-24-2015   #2
Default Re: New LT-5 Wiring Harness...Restomod
So...this is a complete LT5/ZR-1 wire harness with all the connectors in good shape?
I have an interest
Old 12-24-2015   #3
never used brand new
Old 12-24-2015   #4
What year might that be?
I am not familiar with the differences if any between 90-91 and 92-95.
Old 12-24-2015   #5
The engine is a 90, again this was going in a restomod....we can talk on the phone and walk through it if you want. the secondary MAP looks like a 93-95 to me
Old 12-24-2015   #6
The Chip in the ECM said 90 ZR-1
Old 12-24-2015   #7
OK.......I will PM you tomorrow but from what you say (I do have a 95 crate engine with complete wire harness) I can check my crate engine Harness and confirm your suspicion that it is a 95 wire harness.
So you have an ECM and 90 Chip also
And it is brand new wire harness but came with a 90 engine with ECM and chip but you think there is some modifications which look like 95?
I will check when daylight
A couple close up pictures of the ECM connectors and other connectors would be of interest.
Old 12-24-2015   #8
WVZR-1
If it's a modified GM/OE harness it's very likely the wrap with the GM# could maybe still be present.
'90 most likely ..0375, ..0376
'91 ..0870
'92 ..7829
'93 - '95 ..1078
The tag would normally be found wrapped very close to the C100 connector.
Old 12-24-2015   #9
I think this is done by painless or someone like that
Old 12-24-2015   #10
Default Wiring Harness Identification
'91 ..0870
'92 ..7829
'93 - '95 ..1078
Great information......Hot Damn you are good
Lee....what number if any do you find?
I did find a 0376 on a 1990 Harness I am using.
