#21 |
Sooo... In place of the big cube engine for now(depending on crank time on anything bigger than a 368) after we finish the interior and wiring, I will go ahead and drop in the Chrome 91' engine I built in 14':
*Ported plenum and IH's *plenum coolant mod *52K on the block/internals ![]() BTW:...Our plan is further than Evolution Motorsports,..SO with that in mind I will be using the cars that we bring back from the dead and racing them under the moniker "Revenant Racing". When it comes to the rebuild of these cars I will be posting under the website www.revenantracing.com ![]() Last edited by oricale; 02-07-2016 at 09:25 PM. |
#22 |
Just a quick update!
Was pretty bad... ![]() Now not so bad ![]() Cut out the rough fiberglass, will have pics when fixed ![]() Repair harness to be soldered in, NO other damaged wires,..there is a total of 8 wires that burned, although I didnt need to replace the DIC harness, I didn't want to split the bonded wires (better plugs too!). ![]() I have removed the rods', pistons and liners to begin the bigger cube build! (special thanks to Phil for the MUCH appreciated parts!!) ![]() after the harness is fixed and back in place, will install the new hood seal and cable.. ![]() Last edited by oricale; 02-07-2016 at 08:26 PM. |
#23 |
![]() Join Date: Apr 2004
Looking Good
#24 |
![]() Join Date: Nov 2013
big job but will be worth it for sure. this is heavy duty work and only for guys who know or guys who are brave. Love the pics and the quality of work. Good Luck.
ed ramos #3028 |
#25 |
Very much appreciated, thank you
#26 |
![]() Join Date: Aug 2006
#27 |
So!...its starting to come together:
before: ![]() ![]() AFTER!! ![]() ![]() Almost ready for the heart{Chrome} to go in till the big cube is done... ![]() getting the plastic removed: ![]() Done so far? pull and replace engine repair fire damage replace hood seal and sealant replace hood cable and ops check check and replace and bad wiring(soldered in NEW harness's) ...thats off the top of my head......a **** ton more I cant remember Next up?... Chrome Engine install clean and prep tranny sand and paint interior repair area install rubber sealant, dynamat and heat shield padding remove dash pad replace window seal install red carpet Polish and detail exterior(full Two stage plan) Later?... install tranny with short shifter service and ops check car and electrical system pull brakes and replace with 04 Z06 calipers and new rotors Last edited by oricale; 02-10-2016 at 12:56 PM. |
#28 |
#29 |
![]() Join Date: Jan 2004
you need a B&B to go with that car!
just happen to have one. maybe we can do some horse tradin' glad to see you bring another one back from the brink |
#30 |
