Old 02-05-2016   #21
oricale
Default Re: Rehab of the 1992 Blk on Blk
Sooo... In place of the big cube engine for now(depending on crank time on anything bigger than a 368) after we finish the interior and wiring, I will go ahead and drop in the Chrome 91' engine I built in 14':
*Ported plenum and IH's
*plenum coolant mod
*52K on the block/internals
BTW:...Our plan is further than Evolution Motorsports,..SO with that in mind I will be using the cars that we bring back from the dead and racing them under the moniker "Revenant Racing".
When it comes to the rebuild of these cars I will be posting under the website
www.revenantracing.com
oricale is offline   Reply With Quote
Old 02-07-2016   #22
oricale
Just a quick update!
Was pretty bad...
Now not so bad
Cut out the rough fiberglass, will have pics when fixed
Repair harness to be soldered in, NO other damaged wires,..there is a total of 8 wires that burned, although I didnt need to replace the DIC harness, I didn't want to split the bonded wires (better plugs too!).
I have removed the rods', pistons and liners to begin the bigger cube build! (special thanks to Phil for the MUCH appreciated parts!!)
after the harness is fixed and back in place, will install the new hood seal and cable..
Old 02-07-2016   #23
Looking Good
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-07-2016   #24
edram454
edram454's Avatar
big job but will be worth it for sure. this is heavy duty work and only for guys who know or guys who are brave. Love the pics and the quality of work. Good Luck.
ed ramos #3028
Old 02-07-2016   #25
oricale
Very much appreciated, thank you
Old 02-07-2016   #26
ed ramos #3028
And, Dempsey is both!
Old 02-10-2016   #27
oricale
So!...its starting to come together:
before:
AFTER!!
Almost ready for the heart{Chrome} to go in till the big cube is done...
getting the plastic removed:
Done so far?
pull and replace engine
repair fire damage
replace hood seal and sealant
replace hood cable and ops check
check and replace and bad wiring(soldered in NEW harness's)
...thats off the top of my head......a **** ton more I cant remember
Next up?...
Chrome Engine install
clean and prep tranny
sand and paint interior repair area
install rubber sealant, dynamat and heat shield padding
remove dash pad
replace window seal
install red carpet
Polish and detail exterior(full Two stage plan)
Later?...
install tranny with short shifter
service and ops check car and electrical system
pull brakes and replace with 04 Z06 calipers and new rotors
Old 02-12-2016   #28
oricale
Quick update!
Inside of the drivers side after sanding and rubberizing.
*Rubberizing and Dyna-Mat tomorrow
Old 02-12-2016   #29
rkreigh
you need a B&B to go with that car!
just happen to have one. maybe we can do some horse tradin'
glad to see you bring another one back from the brink
Old 02-12-2016   #30
oricale
Whattya lookin for?????I don't have just 1 horse though....their all tied together...
