Old 03-31-2016   #1
Billy Mild
Default ALDL Bluetooth adapter
http://www.reddevilriver.com/ALDL_Bluetooth.html
Has anyone seen this? Anyone used it before with ALDL Droid?
I'm looking for a solution that is a little easier to use than carrying around my MT2500. I would like a recording ability if possible, but I'm unsure if ALDLDroid will supply that.
Old 03-31-2016   #2
Default Re: ALDL Bluetooth adapter
I use ALDL Droid ( I gave the Developer the LT5 file for use in it)
Anyway, while I don't use that specific adapter I use this one:
http://www.1320electronics.com/products.html
Both should work with ALDL Droid and Yes, ALDL Droid will record data
Old 03-31-2016   #3
Slick a ALDL BT Dongle.... and it works with Tuner Pro as well. I had not seen this yet but I am happy they still support the older cars. Would be good for on the go trip wise.
Old 03-31-2016   #4
Now lets get the apple interface up and running
Old 03-31-2016   #5
lbszr
lbszr's Avatar
Is the ads file the same as the adx on Tunerpro? Cause I don't see the adx for a 90 that it says is needed for the app to work.
Old 04-01-2016   #6
No but if you Pm me your email Address I can send the one I made for ALDLDroid.. it will work directly with TunerPro
Old 04-01-2016   #7
lbszr
lbszr's Avatar
Thanks, PM sent.
Old 04-02-2016   #8
KJP
The developer for the ALDLdroid is a very supportive of his product and is quick to respond to any issues you may have either with the app or the files. Well worth the money.
Ken
KJP is offline   Reply With Quote
Old 04-02-2016   #9
We tried Jeff's .adx on my 92 and it appeared to work fine.
Old 09-24-2016   #10
Billy Mild
I finally got my ALDL bluetooth adapter to work and connect to my phone/tablet. It seemed to be working great in the garage, but then I pulled out onto the street and I had "Checksum Mismatch" errors. It wasn't keeping up at all with the readings. Any thoughts on what I can do?
I'm trying to do some testing to see if my ECU is bad.
