Old 05-11-2016   #1
cuisinartvette
Default Owners with smog issues inside
How many stockers are having issues passing smog?
Please name yr stock or what mods
If you can list the categories you are off by and how much along with required standard.
Thanks!
Old 05-11-2016   #2
tpr60
Default Re: Owners with smog issues inside
1990 stock, passed Calif. smog last Monday no problem. 64k miles. Fresh spark plugs, o2 sensors, no vacuum leaks, manual control of fans to keep temp at 180.
tpr60 is offline   Reply With Quote
Old 05-11-2016   #3
1991 bone stock @16,000 miles failed twice. No trouble codes and car running great. The Nox level was over the 502 max limit. I've got a few easy mods but whenever it's time for a smog I, well can't divulge that here but I get some help from Mr.H only because the State has continually dropped the standards. It went from 702 max Nos down to 502. Last time it smogged I think it was 300 Nox. What's interesting,this car with 6000 original miles would not pass current smog regs today. It doesn't seem legal that the State can keep dropping the standards. Looks like this might come to a head if it drops anymore.I might add that whenever it's time for a smog a smog check all my legal mods come off and the car goes in bone stock,considering how hard it is to get it to pass I need all the help I can get.
Old 05-11-2016   #4
mike100
Originally Posted by Z51JEFF View Post
...I think it was 300 max Nox. ...
can you check your sheet? last time for me it was the 500 and something level.
Old 05-12-2016   #5
My apologies,the MAX after 300 shouldn't be there,it's 502 max Nox for the State level.
Old 05-12-2016   #6
8cam
Had a helluva time getting my bone-stock 90 to pass, kept failing nox levels too - vacuum leaks, o2 sensors, throttle body sticky, coils, plugs, wires and more. Finally got it to pass and now I never have to worry about it again, thanks to the 25 year rolling exemption here in GA. Oh and it runs like a bat outta hell now.
Old 05-13-2016   #7
Performawheels
Here's my last smog print out. Power effects Cat back, K&N open lid, chip programmed around mods.....passed with no trouble...1994 #308.
Performawheels is offline   Reply With Quote
Old 05-13-2016   #8
It should be noted that most of the problems are with the early cars that don't have an EGR valve.
Old 05-14-2016   #9
mike100
I have a plan "C" to cheat like Volkswagen by not only doing the cooling fans on sooner, but lowering the ignition timing tables below 3000 rpm (primary ports) on a smog test chip.
If VW could fake the funk on NOx so can we. That said I have been hitting ok numbers the last couple of times.
Old 05-15-2016   #10
Ah,yea. V.W. got cought and I don't want to that's why I won't reveal my secrets here but if C.A.R.B can be so chickin $hit as to lower the standards than I'll do what I got to do to get it done. I might look into a class action lawsuit against C.A.R.B. but wouldn't know where to start.
