Old 09-06-2016   #21
Default Re: Short throw shifter?
Daryl, (sp?)
Mine has stock cams and is nearly quiet. Ami's has the Al flywheel & Pete's cams ... and it rattles...A LOT(in neutral/clutch not engaged).
I've heard both with and without the sprung hub, and the sprung hub does seem to be quieter...unless the LT5 has "cams" OR an injector or two that are bad.
Pardon me Paul, but is it possible you meant to say it rattles a LOT when in neutral with the clutch pedal up (clutch engaged) instead of pedal depressed which would be clutch not engaged?
Old 09-07-2016   #22
Yes...I think...foot OFF the clutch. Or...is it when my foot "engages the clutch" is the clutch engaged (by my foot) and disengaged w/ my foot OFF??
Let's go w/ your definition! LOL
Old 09-07-2016   #23
BigJohn
BigJohn's Avatar
Yes!
Old 09-07-2016   #24
Daryl, (sp?)
There is a YouTube video of mine with an Aluminum FW and a sprung hub. 508 hp LT5, IIRC will get you to the YouTube video.
Thanks Paul saw the vid she sounds good. I'm running Pete's intake cams so Im thinking it wont make much difference
Old 09-09-2016   #25
Dom, how is the FW Rattle with that LT1 Sprung hub?
GC,
The LT1 slung hub disc mitigates the rattle. It shows up at idle but no where else on my car, and even then it depends on how hot the trans oil has gotten,
I have done quite a bit more tuning since your calibration and I had Ted Feder
listen to the motor at The Gathering this year. Maybe he'll chime in w his impressions.
