Old 10-24-2017   #1
Default LED Tail lights
I have an aftermarket set of enclosed lenses with LED..
But has anyone done a Replacement LED bulb in the OEM Houing?
Old 10-24-2017   #2
Default Re: LED Tail lights
I’d like to see that too. I did see a few months back that AutoZone was carrying
tailight bulbs for durectional and brake lights. They were $20each. With Euro lamps, that’s $160.
Old 10-25-2017   #3
davekp
I did a replacement bulb - brighter than the incadescents but the improvement did not look that dramatic to me.
davekp is offline   Reply With Quote
Old 10-25-2017   #4
Folks did this on the earlier C4 with the round taillights and it looks like a clown nose with a bright center dot as it did not diffuse the light well. If it was to be done again I would suggest using a RED LED replacement blub to resolve this problem. I am happy with my LED taillights that are in the whole housing so this is a mod that I will not be doing. GC
Now if they were to do the whole LED housing in the EURO set up I would like to see that
Old 10-25-2017   #5
I have aftermarket LED tail lights, but was curious on the replacement bulb.. Davekp, if it was equal to OEM that is a good thing, but my concern was if there was a bright spot in the center
Old 10-25-2017   #6
that's what I was trying to say. However maybe with a red LED replacement that bright dot might go away and be better diffused. I also remember what you have -=JEFF=- as mine are similar but have more individual LEDs that make that kinda cross pattern
Old 10-25-2017   #7
that's what I was trying to say. However maybe with a red LED replacement that bright dot might go away and be better diffused. I also remember what you have -=JEFF=- as mind are similar but have more individual LEDs that make that kinda cross pattern
Yes, I get it, but you were talking about the round lights.. If I could I would swap the red lenses on my lights and OEM to try, as the LED ones I have are a bit more orange than the OEM lenses.
As you can tell, getting stir crazy..
Old 10-25-2017   #8
Here is a picture of something I was playing around with trying to see if I could do a halo.. the main bulb was a Amber or white (all I had) but the center of the lens has a bright spot.
Here is a picture when I was switching lenses. Right has OEM bulbs
Old 10-26-2017   #9
davekp
I didn't notice any bright spot. Looks to me like OEM, but slightly brighter.
Old 10-26-2017   #10
BigIke
There's a dude on facebook that will build angel eye tails pretty cheap, I'll see if I can find the pics. I know I'm a little off subject
BigIke is offline   Reply With Quote
