02-09-2018 | #11 |
Re: High searching Idle
02-09-2018 | #12 |
Old one on the bottom, new one on the top..[ATTACH]
Sent from my XT1585 using ZR-1 Net Registry mobile app |
02-10-2018 | #13 |
Put the new PCV connector on. Guarantee no leaks there! It's darned tight! Fired up the engine. High idle 1300 rpm, until closed loop kicked in. Dramatic swings in AFR as fueling was dithered. Finally settled down at full coolant temp (193F). Idle still sits at 1175 versus commanded 750. IAC locked at 0 trying to adjust idle to commanded. Verified IAC working. Stepper motor kicked in at 1325 room (4), then rises with increase in rpm. Now suspect something went wrong in the TB. I'll put a borescope under the plenum just to make sure no other vacuum connections are off. Then I'll pull the bellows off and use the borescope to look closely at the TB blades during idle and increasing rpm.
Steve Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
02-10-2018 | #14 |
Sounds alot like the MAP hose. Off, broken connector, or plain rubber line with low point oil collection in low point. The rubber connectors on each end of the hard plastic pipe are prone to tear due to age. If you can reach, remove the MAP hose from the plenum barb & put your finger over the barb to see if the high idle is due to the MAP hose.
The lower dual PCV hose in mine (94 w/57k) was rock hard on the side towards the firewall & completely rotten on engine side.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-10-2018 at 08:28 AM. |
02-10-2018 | #15 | |
02-10-2018 | #16 | |
The MAP hose is not off, nor broken. Checked that again this morning. The connections are tight, including the 90 degree fitting on the bottom of the MAP sensor. I'll pull it to make sure it's clean however. I also checked the PCV hose while replacing the top fitting. Pliable and tight. No issues that I see there. Sent from my XT1585 using ZR-1 Net Registry mobile app Last edited by jss06c6; 02-10-2018 at 10:29 AM. |
02-10-2018 | #17 | |
02-10-2018 | #18 |
At the risk of stating the obvious. You checked both MAP sensors, right?
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
02-10-2018 | #19 | |
Could point to either vacuum leak, or TB issue.
02-10-2018 | #20 |
Not yet but definitely part of the diagnosis..
