Old 06-19-2018   #31
George Maz
Default Re: Got clawed
Bought it "new" on eBay $275, (more like a factory blemish)
Inspect the inside for loose powdercoat, paint...poor prep work.
Didn't return it since mine needs to be stripped & refinished anyway to match engine color, like was previously installed by a previous owner.
Filter elements came blue, so need to change that to red. The K&N recharge kit has red dye.20180619_225003.jpeg20180619_225106.jpeg20180619_225147.jpgIMG_5840.jpeg
Sent from my SM-N920V using ZR-1 Net Registry mobile app
George Maz is offline   Reply With Quote
Old 06-19-2018   #32
RussMcB
I don’t believe you need to worry about that on our LT5 and maybe for LT1 only? Mine was capped off with silicone cap and both my 90 and 95.
Me, too. Mine has been capped off since I've owned the car.
Old 06-19-2018   #33
bongo577
Thanks guys...any Idea where can get a cap???
bongo577 is offline   Reply With Quote
Old 06-19-2018   #34
HAWAIIZR-1's Avatar
Default Got clawed
At first I had just a rubber cap from local auto parts, but later bought a SAMCO cap. I couldn’t find the part number, but if you want silicone it will be called a blanking cap and you just need the measurement of the fitting. You want it tight fitting and no clamp necessary if so.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-20-2018   #35
bongo577
If it's not too much trouble to get the Samco cap part Number...it would be much appreciated!
Thank You,
Old 06-20-2018   #36
bongo577
Sorry...I re-read your post saying you couldn't find the samco part number...
Old 06-20-2018   #37
HAWAIIZR-1's Avatar
Actually my apology and had to edit the typo from reply on phone. I’m in Hawaii and away from my car in Japan or I could measure and tell you what cap you need. If you have a micrometer you can measure the inlet pipe OD to get the ID of the plug you need. I won’t be back for another week. Hopefully someone else will reply with the part number. Searches on the interweb did not work for me. Best wishes.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 06-20-2018   #38
bongo577
Thanks for all your help! I was able to find one locally....
Old 06-20-2018   #39
HAWAIIZR-1's Avatar
Great news John!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
