Old 11-11-2019   #11
Default Re: Polycarbonate windows
Originally Posted by Karl View Post
I am not sure. Guessing 30 to 40 lbs.
I am thinking maybe a bit more.. that is a big piece of glass
Old 11-11-2019   #12
Corvette Forum has a weight sticky in the General C4 Topics section one person noted it as 30lbs
Old 11-12-2019   #13
RussMcB
I am determined to try and drop 300lbs on my car this winter and this looks to be a good part.
300 - 20 = only 280 more to go! :-)
Old 11-12-2019   #14
Vette Guy
Vette Guy's Avatar
The poly glass does not hold up as you may believe. It does scratch easy, does not remain crystal clear, and must be fastened and used with reinforcement braces, else it will flex and break. I run glass on the front and poly rear. They do make side windows, but really only for security - I have a set. You'd never want to run them at speed, rather best installed to deter thieves from easily getting into your car.
300lbs? Consider CF hood, CF doors (if you can find them), CF roof, removal of headlight assemblies, A/C, heater core, condenser, inner fenders, radio, speakers, racing battery, inner door panels and carpet. Nothing heavier than factory A-Molds (20.5/22lbs). No coil-overs and lose the rocker panels. Don't forget to balance the car when you are done!
Hope this helps!
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 11-12-2019   #15
Karl
Karl's Avatar
Why don't you use the door window's?
Losing the first 100 lbs will be relatively easy.
Losing an additional 200 to 300 lbs will be difficult.
If I can drop 150 to 200 lbs I will be happy without changing body panels and losing the a/c,
I figure a ceramic window tint that reflects +90% of UV rays will help protect the windows.
Old 11-12-2019   #16
Vette Guy
Vette Guy's Avatar
Race car. Use them only to keep folks out.
Mark Horner
91 ZR-1 #2016
Old 11-13-2019   #17
spork2367
I worked at a shop that resold and machined LOTS of engineering grade plastics.
Polycarbonate is very soft and does scratch easily. If it has mar resistant coating (like MR10) it has a very thin very hard coating, like headlights. It is still very easy to put a deep gouge right through the coating.
Polycarbonate (trade name Lexan) will not "break". Acrylic (trade name plexiglass) will. Acrylic is much harder and scratch resistance and has shorter chain polymers and will crack and break. Polycarbonate with its long chain polymers will take repeated bends in the same direction over a very long period of time before it will break.
Old 11-13-2019   #18
Locobob
I've been playing with motorcycle aluminum fairing bolt kits... you can save about 1lb by doing all the front wheel well fasteners... yeah I know its kinda silly but it all adds up.
Robert
Old 11-13-2019   #19
Pete
Pete's Avatar
Bob, i got to a point where i have done all i could to minus weight now 1lb sounds like 100
The rear Polycarbonnate 1/4" thick glass sounds pretty durable heck it's 1/4" thick how bad can it be?
I'm scared to try light battery don't wanna get stranded. unless somebody has tried light battery any input would be great.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-13-2019   #20
Karl
Karl's Avatar
How much does the stock battery weight?
I use the Odyssey PC925L and it weighs 23.8lbs.
It is noticeably smaller and a AGM battery. Car starts right up.
