Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Technical Questions
Old 06-19-2013   #1
Rex Ruby
Default High pitch noise
Have a high pitch noise when the engine is running.
Doesn't seem effect performance but something isn't right.
Any ideas?
John Porter
'93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels
* PA Plate: OBSSSN
'06 LeMans Blue C6 Coupe - Corsa exhaust
* PA Plate: OBSSSV
ZR1 Net Registry Founding Member #153
40th Anniversary Registry Member
NCM Family Membership #8116
Corvette Forum NE Events Coordinator
Delco Cruisers Board of Directors
SAVE THE WAVE!
Rex Ruby is offline   Reply With Quote
Old 06-19-2013   #2
scottfab
scottfab's Avatar
Default Re: High pitch noise
Can you localize where it's coming from? Font ? Rear?
Motor? wheels?
Well I had a "whistle" noise coming form the TB.
It ended up being some build up near the plates.
I took the bellows off and wiped them down and reapplied
grease (it facilitates full closure).
The whistle went away.
Scott
Old 06-21-2013   #3
Rex Ruby
I'll check that Scott.
Noise is coming from the engine.
John Porter
* PA Plate: OBSSSN
* PA Plate: OBSSSV
SAVE THE WAVE!
Old 06-21-2013   #4
scottfab
scottfab's Avatar
If it is not a high pitched whistle but more of a metal on metal squeal then you can take paper towel core (tube) or a 2ft section of hose and use it to your ear to aim at the water pump, alternator, idler pulley, etc to try and localize it.
Get a suspect then remove the belt and turn each by hand.
If the noise goes away once the engine is warmed up then suspect the water pump. Maybe it's time to flush and put in new fluid? Or add some water pump lube? If that makes it go away then it would be wise to keep close watch for fluid drips for a while.
Scott
Old 06-21-2013   #5
Plenum to inj. housing vacuum leak ?
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 06-21-2013   #6
Frank,
I just had this happen. Turns out my fuel rail bolts were loose. Injectors and rails could move around. That should be the resolution of my "disappearing IAC counts" at idle. So I ran the 1/2mile and Dyno that way.
DUH!
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-01-2022   #7
stuntmanmike
Hi guys, I?m experiencing a constant squealing noise. Does not change much with engine RPM. When you shut the motor off it continues for a couple of seconds then sort of tapers down in frequency, like a bottle rocket sound.
Do I need to pull the whole Plenum off to get access to the injector housing that may be the culprit? Thanks
stuntmanmike is offline   Reply With Quote
Old 04-01-2022   #8
Yes.
Old 04-01-2022   #9
Jagdpanzer
Jagdpanzer's Avatar
Sounds like a vacuum leak
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
