Old 12-13-2022   #1
tokuzumi
Default I have the J55 RPO, but pretty sure I have the 12" rotors installed
Need to replace the front rotors/pads/calipers, as I had the car pull to one side during a recent drive. Only happened once, but this kind of issue won't just magically go away.
Looking at my RPO codes, I see J55 listed, which are the heavy duty brakes. Everything I've read, this means it includes the 13" rotors in the front. But I think this car has had the rotors replaced with standard 12" rotors. Pic below of my wheel for reference. Please don't judge too much for the dirty car.
If I go to replace everything with the J55 stuff, do the caliper brackets line up, or are things different? Suspension codes are FE1 and FX3, so I do not have the HD suspension.
I knew I was having a heck of a time finding the right parts for some reason, and if the HD rotors were replaced with standard rotors, this would make sense.
tokuzumi is offline   Reply With Quote
Old 12-13-2022   #2
Ccmano
Default Re: I have the J55 RPO, but pretty sure I have the 12" rotors installed
Yup, at the very least those are the wrong rotors. Without better photos it looks like the Calipers are correct. All ZR-1's had J55 standard..
H
Old 12-14-2022   #3
Mikey
I?d venture to say your brake pads are half hanging off that rotor!
Old 12-14-2022   #4
Everything will line up. Do you need a complete front J55 setup? I have the original equipment that I removed from my car when I upgraded.
Old 12-15-2022   #5
Mikey
He might just need the right size rotors and pads. Calipers could very well be correct already. that would make this an easy fix.
