Old 03-30-2008   #21
Default Re: Off idle stumble...................
Originally Posted by tpepmeie
Not true. There is a delta TPS AE factor. I do agree with your prior experience, the TPS-based enrichment does provide a better response off-idle.
For what it's worth, going from memory, the TunerCat tables/constants are not exactly labeled right for some of the AE items. What you see is indeed the Delta MAP AE table. If I recall the earlier calibrations have a rather flat enrichment regardless of D-MAP, while the later (BMCB) is more sloped. I think some of the other TC items are labeled wrong. I don't have it installed, so can't check it anyway.
A final "for what its worth", the very early development calibrations relied exclusively on D-TPS enrichment. The D-MAP feature didn't get put in until later, from what i can tell.
Todd.
Todd,
From what I've been able to see there isn't a AE PW table based on Delta TPS%. I do see a constant for Delta TPS% to allow MAP AE but again no table. The stock 92 bin has a flat AE PW for MAP. Which cal year started using the "sloping" AE? I'd like to look at that.
With modded motors it may make sense to add a bit of decay and possibly increase the PW a bit at the lower Delta MAP. Probably want a bit more fuel going there at smaller Delta MAP since tthe secondaries are not likely to kick in.
Old 03-30-2008   #22
tpepmeie
Originally Posted by XfireZ51
Todd,
Dom,
You're using TunerCat, right? There are probably 500 items not defined in TC's definition files. D-TPS Acceleration Enrichment is among them, constants AND tables. And, as I said, don't think the AE things are all labeled right in TC anyway. I will say that the initial D-TPS AE term is not a traditional table like the MAP AE is, but it is in there nonetheless.
The BMCB is one that I know has the sloped MAP AE values.
This is without a doubt the most frustrating part of any calibration to get right. It's a delicate combination of many factors to get it just right. And lots of trial and error, and trial again.
Todd
Old 03-30-2008   #23
Todd,
I use TunerPro RT. Tunercat has a 99 item limitation. Any chance you'd send or post the section of the code with the D-TPS table for AE?
Old 03-31-2008   #24
cuisinartvette
Have you tried Jeff? Why not support someone who supports the forum,
bet he could take care of you.
