Old 07-27-2008   #1
Default 90 ZR-1s and fast idling?
Assuming (otherwise) normal operation, is a 2000 rpm initial idle "normal" for the 90 Zs?
Even after it warms up, I have a fast idle after coming to a stop (sign) after normal (for me and a Z) hwy speeds. If I sit in neutral and let it idle, the idle speed evenually drops to "800 (my tac) after about 15 seconds or so. After that and it will idle normally at a stop light/sign every time. Otherwise, she'll seldom come off of 2k idle w/o first pausing somewhere to let it adjust.
I seem to recall something about this little quirk and the 90s. Is this normal? Does Marc H's have this handled in one of his chips?
Other than that, she runz like 'er azz was on fire!! WHAT A BEAST!
TIA,
P.
Old 07-27-2008   #2
Default Re: 90 ZR-1s and fast idling?
Paul there is a TSB over at the netreg site about this 'quirk' on the 90's. There was no recall issued. Just an updated EPROM as an answer to what you are describing if the customer made complaints about this condition to the dealer while under warr.
I remember reading the TSB and I bought the updated EPROM back in 05 from a dealer, $40.00, and it almost eliminates the issue. It still 'hangs' a bit but returns to normal much quicker than my original EPROM. There is a thread about it here where one of the guys that are into writting their own EPROM's listed all the changes on the updated EPROM....quite an extensive list of changes & interesting reading.
Old 07-27-2008   #3
32valvZ
32valvZ's Avatar
I JUST, as in this week, got my chip back from Haibeck & my 92 is doing pretty much the same as yours Paul. When I start it up it soars to like 2000rpm & hangs there a few seconds. Then also like yours, it seems to hang when coming down from cruising speeds as I approach a stop. I noticed this both before & after the changes Marc made to the prom.
Old 07-27-2008   #4
Aurora40
Aurora40's Avatar
My car has only done that when it had leaks. When I bought it, it already had the latest PROM, and I've had Haibeck PROMs since. Mine only idles high when the car is moving, like when slowing to a stop in neutral it will idle around 1000-1200, but drops when the car stops.
If you can scan it, look at what the "desired idle" is and also if the IAC counts come down when you stop. If so, but the idle doesn't drop, it's a vacuum leak. If it doesn't command it down, perhaps you need an updated PROM.
Old 07-27-2008   #5
RedSled
My '90 will sometimes do the same thing, but doesn't reach 2000rpm. More like 1500-1600. Then it will normally return to a 800-900 idle after 10-15 sec. It has consistently done this for the three years I have had the car.
-Keith '90 Red/Red #1383
RedSled is offline   Reply With Quote
Old 07-27-2008   #6
32valvZ
32valvZ's Avatar
[QUOTE=Aurora40 Mine only idles high when the car is moving, like when slowing to a stop in neutral it will idle around 1000-1200, but drops when the car stops.
Mine does this exactly. So I guess thats a normal condition.... When it first starts it idles high for 3-10 seconds. It seems kind of excessive though. Its actually around 1600 rpm, not the estimate of 2000 that I mentioned earlier
Old 07-27-2008   #7
Aurora40
Aurora40's Avatar
I think they all rev up a bit on startup, I always thought it was kinda cool. Like it was sleeping, and now it's awake!
Old 07-28-2008   #8
I guess it gets that oil a splashin' up under the pistons right away - a good thing on a cold start, I suppose.
P.
Old 07-28-2008   #9
tccrab
tccrab's Avatar
This has been a pet peeve of mine for a while.
I have a Haibec prom and the idle is much better than the original factory prom.
When I start the car she idles fine.
After I drive it a little while and roll up to a light sometimes the idle does not return to 600, it seems to hang at 1000-1200. Sometimes it goes down to 600 after I stop, sometimes it doesn't.
If I tap the gas slightly as I roll to a stop the idle goes down to 600.
I've always thought it was something in the throttle body, maybe gunk or something that doesn't allow the blades to close properly.
I've been afraid of messing with it for fear of f'ing up the magic black goo that seals the throttle plates to the throttle body.
In the good old days of Holly carbs you could spray cleaner down the carb with the engine running and clear gunk off of the throttle plates and stuff.
TomC
Old 07-28-2008   #10
TomC
The high idle on start is an emissions thing to get the cats and O2s lit asap. Same for the high idle under freewheeling. Its emissions. There is a decay delay set in the prom which can be changed.
As for goosing the throttle and idle dropping, I would clean the TB and also the IAC and passage.
