Old 11-24-2008   #1
Pete
Pete's Avatar
Default Track Times: My Best Ever
Took my Z to the track today Great Lakes Dragway last time till spring.
I put my Z on 2 different Dynos (Dynojets) and ran her at 2 different tracks to back up my ET's/MPH.
About a month ago went to a vette track rental US41 temps were 80's she ran 11.40's @ 128, today temp was 44*f ran 3 passes then i got the boot.
1.78/11.32 @ 129.05
1.86/11.50 @ 129.23
1.74/11.09 @ 129.27
I'm very happy with my Z
Now for a few more little performance tid bits over the winter (maybe gears),shooting for 10's and 130MPH then i'll be ready for BG.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-24-2008   #2
Default Friggin fantastic!!
WooHoo, buddy! U makin friends of the KOTH proud! (And, a N/A 350 at that!!) That Z of yours is a "hall of fame" candidate for sure! Congratz, Pete. I know you've put a lot of TLC into that car, and it surely shows it. I sure would like to be there when you break into the 10s...have to break a bottle of Campaign over the hood...well...mebby not. But! it will be time to party
For others reading along, some perspective: Pete's Z was the top dog at the Corvette gathering at US 41 a few weeks ago - over all comers including several C6Z06s.
Well, gotta go to work, but thought I'd check in and see what was going on. Glad I did!
P.
Old 11-24-2008   #3
Wink Re: Track Times: My Best Ever
Pete,
I wondered if you were going to go yesterday. I would have come with but had go to a previous engagement involving my daughter. I don't have to tell you that daughters take priority over drag racing. =Jeff= and I may have a way of getting you into the 10's.
Old 11-24-2008   #4
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Track Times: My Best Ever
Pete,
Those are some fantastic times and speeds out of a stock displacement NA LT5 motor.
What tires were you running?
With those hard launches what are you doing to keep from breaking spindles, u-joints, and half-shafts?
Are you running stock spindles?
And what gear ratio are you planning to go with?
Last weekend I broke the right spindle on mine on the first pass I tried at the strip. Now I'm in the process of putting it back together and would appreciate any advise you can give on how to make the drive train more reliable for occasional strip use.
BTW I had those skinny A-molds on you sold me a while back with some new Hoosier radials on and they sure looked good on the car.
Old 11-24-2008   #5
Demps
Demps's Avatar
Awesome Pete! Sounds like the car is making some power. AND, looks like you're not too shabby of a driver. Great work!
Old 11-24-2008   #6
Aurora40
Aurora40's Avatar
Wow, that's amazing! How much does the car weigh?
Old 11-24-2008   #7
Pete,
Couldn't you get the same result by dropping $130K on a new 09 ZR1? Most of all your car doesn't even have a fishbowl on the top of the hood.. I think the idea that Dominic and Jeff have is to fab up a plastic blue engine cover to put on top of the LT5, its worth 15-20hp.
92 ZR1
#234
Old 11-24-2008   #8
QB93Z
QB93Z's Avatar
Great racing Pete, you should be very proud.
Old 11-24-2008   #9
jonszr1
jonszr1's Avatar
simply awsome big guy . just let me know if and when you want to try out a new gear set. i have 410s,392 and 373s at your disposal . thought you might want to try the 410s with a 27 in tall tire . might be the ticket
Old 11-24-2008   #10
jonszr1
jonszr1's Avatar
pete , looks like the coil overs helped . on the 09 run did you go to the soft setting . on my snat i just used the middle setting but after seeing the vids on u tube i think i will try the softest setting
