Old 02-26-2004   #1
wikdzr1
Default Detonation at 6500 RPM
I was wondering if any one experiances any detonation at high RPM. I use 94 sunnoco fuel. Around 6000-6500 rpm I hear the valves rattle?
Any thoughts?
Also I heard a loud pop ( Metal snap sound) when backing up the otherday. Now periodicaly I hear a squeak or pounding while driving. I have pulled the wheel but it looks okay under there. I have also slid under my car and looked at u-joints etc & cannot find anything out of norm. any ideas
wikdzr1 is offline   Reply With Quote
Old 02-26-2004   #2
Z Factor
Z Factor's Avatar
Default
Hello, and welcome to the forum.
I have never experienced the problems you described, so I cannot say for certain what you heard/ are hearing. Have you had your car tuned, or has it been a long time?
Old 02-27-2004   #3
wikdzr1
Default
I have replaced the plugs a few months back & set to .050, i plan to pull the plentum & replace the wires in spring.
Old 03-01-2004   #4
Patton
Patton's Avatar
Default
Hell at 6500 what isnt rattling!
What do you mean?
Patton is offline   Reply With Quote
Old 03-11-2004   #5
Default
When is the last time that the fuel filter was changed ?
Old 03-31-2004   #6
wikdzr1
Default
I have not replaced the filter as of yet! 65k miles I will ASAP! It is my U-joint I will replace this week!
Old 04-03-2004   #7
Default
How did the fuel filter change work out for you ?
Old 04-06-2004   #8
wikdzr1
Default
I did not get a chance to change it yet, I will let youknow as soon as I do. I also found that I need to replace the U-joints
Old 04-08-2004   #9
1990 quasar blue
Default
I posted a link on your last post to help with the u-joints. What's the chance you have a heat shield making the rattling noise? Just a thought.
Old 05-19-2004   #10
wikdzr1
Default
Thank you for the information, Mark Haibek is currently changing out my gears to 4:10 . I will let youo know the outcome.
regards, Brett
