Old 11-16-2009   #1
Gary Yarbrough
Default Leaky Radiator
On Friday, I spent some time trying (yet again) to troubleshoot my rough idle. I should have known better, given that it was the 13th! No luck... I was shut down early because of another issue.
I found that I have a leak in my radiator. This is the 2nd radiator to go bad in the last six months. I remember reading once that the cooling system has a pressure relief function. Can someone enlighten me on how that works and if some flaw in that system is causing my radiators to go bad? Is there something else that is likely to be causing my problems?
Gary Yarbrough is offline   Reply With Quote
Old 11-16-2009   #2
Default Re: Leaky Radiator
Are you running low temp thermostat?
Before I found out our thermostat needs bypass holes I had a 160 degree thermostat installed without any bypass. I strongly suspect this led to my radiator failure.
Old 11-16-2009   #3
Gary Yarbrough
I believe I'm running a stock thermostat. But, it could have been changed before I bought the car and not recorded...
Old 11-16-2009   #4
Also check and, if necessary, replace coolant reservoir cap. This is another point of pressure relief.
As far as I know, these two, improper thermostat and/or reservoir cap, are only things that could hold pressure to a point of rad failure.
Pressure relief function you are thinking about may be the bypass feature of the thermostat to relieve coolant pressure at high rev.
Old 11-16-2009   #5
Gary Yarbrough
Thanks! I'll check both out.
I'm leaning toward the bypass feature of the thermostat b/c my leak is happening at high rev. I'd say 5500 to 6500 RPM.
Old 11-16-2009   #6
jonszr1
jonszr1's Avatar
there a re some therms that are for sale out there that have the wrong type of bypass feature that can cause what is happening to you , napa sells a known good type .or you can get one from randy woods at srp products. his arent cheap but they are of great quality and you can get them in 160-165-170 degrees . i use his thems in all my cars
Old 11-16-2009   #7
QB93Z
QB93Z's Avatar
Here is a picture of the thermostat from my 1993 ZR-1 for comparison:
Old 11-16-2009   #8
Keep us posted as to what you find. I am curious.
Old 11-16-2009   #9
2ZR1S
2ZR1S's Avatar
I destroyed a brand new Fluidyne aluminum radiator by installing an after market thermostat. $500 dollar lesson learned.....
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
Old 11-16-2009   #10
Ouch! Sorry to hear that. I cracked my radiator, I suspect, for the same reason but the car had about 50,000. I got a used replacement that was pulled out of a 94 ZR-1 w/ 5,000 miles belonging to another forum member for $50!
Come to think of it, I just replaced all my rotors out of another 94 ZR-1 given to me by another forum member free!
NCRS folks, please note they are both 94 ZR-1 factory originals!!!
