Old 06-20-2010   #11
Default Favorite tools
I started a thread a while back on the subject of favorite porting tools. It proved quite interesting, I think.
http://www.zr1.net/forum/showthread....hlight=Porting
As for the bits fouling, plain ol WD40 on the work and on the bit worked extremely well for me - far as cutting and keeping the bur clean.
After trying a variety of tools, both electric and pneumatic - cheap and better quality, I guess it is no surprise that the good stuff is waaaaaay better than the cheapo stuff, IMO.
My favorite tool is the long Snap-On pneumatic. It is relatively light weight, and very controllable when using both hands, speed is infinitely variable continuously, and is instantly on or off. By draping the hose over my shoulder and using both hands on the tool, locking elbows and using my legs and hips to move me and the tool as one...worked very well for me.
For certain "easy does it" jobs, especially at lower speeds, I found the electric grinder has its place as well. But, I almost gave them up because using them in conjunction with a speed controller, the torque left a lot to be desired, and the speed would drop under load.
However, the Makita mentioned in the thread is a whole different animal! It is a constant speed tool, and even at low speeds there is tons of torque and speed is constant under load. Quite a tool, to be sure.
Have a look. Anything you want, I can get less than 10 minutes from my work at Fleetwood tool in Addison, or the Snap-On dealer practically next door to Fleetwood.
P.
PS I tried using the Harbor freight speed controller on a modest quality electric
Old 06-20-2010   #12
Default Re: Stage 1 Porting
I used a good quality electric grinder with a Harbor Freight speed control. The burrs are double fluted to avoid cutting too deeply. Makes for a smoother finish to begin with. Then various grit ball hone to finish it up.
Old 06-20-2010   #13
4.5hrs on the 1st IH and they are pretty much done......36mm at the top, moved to 35 at the boss, and narrows to 33mm at the IH to head surface.
Bosses are gone.
2ndries are at 36mm
I am interested to see the performance difference if any, its amazing how much time it takes to open up the area after the boss and the IH to head surface in comparison.(meaning going to a few mm/36 takes forever in comparison)
Old 06-22-2010   #14
flyin ryan
flyin ryan's Avatar
ATF works good too. Keep some in a cup & dip your burr....
Old 06-22-2010   #15
Locobob
I use a spray lube called Mega Foamcut, Ace Hardware has it.
Robert
Old 06-22-2010   #16
Are you talking about porting or porking????
P.
Old 06-27-2010   #17
Would anyone be interested in doing this type of set up for $425 plus shipping?
Let me see what my total time into it would be....I believe that this porting is not much different than what some charge much more for and is considered fully ported.
Old 06-27-2010   #18
Hammer
Hammer's Avatar
Talking Re: Stage 1 Porting
P.
Old 06-27-2010   #19
Not cleaned up yet.....but you get the picture
Old 07-03-2010   #20
Topfuel
Topfuel's Avatar
When porting aluminum use bar soap on the bit or use ATF dip bit into one or the other ever so often it really keep the bit from gumming up. Soap seams to work better for me. ATF or WD-40 adds oil to the pores of the aluminum and if you have to weld on the Aluminum afterwards the oil will mess up the welding just my .02 worth
By the way looks good that is what I did to mine much much better than stock. Keep the slightly rough surface on the ports helps keep the boundry layer smaller on the air flow.
Topfuel is offline   Reply With Quote
