![]() Join Date: Dec 2005
I think I am going to have my Charcoal 1990 judged at our chapter meet in early October.
Hopefully everything will work on the judging field!!!? ![]() |
![]() Join Date: Oct 2008
It's not the kiss of death, but Operations can knock you out of a Top Flight. My 90 scored 97.5 (first time judged), but suffered the following FUBARs:
* Right headlight would not go up (just had it repaired) * CD player did not work (repaired previously) * Glovebox light flickered (still need to get a new switch) * Was hit for non-existant inflatable bolsters on seat bottoms (I should have known my car better, but two judges were telling me the same thing) If all these were fixed I would have scored 98.5. 10 points could be the difference between flight awards. If you drive the car you can get some points back, as well as having an NCRS sticker, fire extinguisher and battery disconnect. Good luck and let us know how you do. Jim |
David,
Cohoes, NY I've got lots of work putting the original parts back on. ![]() |
![]() Join Date: Dec 2004
![]() ![]() ![]() Good Luck John! ![]()
![]() Join Date: Jan 2010
John,
Let me know if there's any bits or pieces you may need. Key knockouts, original air cleaner element, tags, lug nut plastic bag or ? Don't forget to WD-40 your storage bin lid latches so they latch when dropped from 6" or so. Doug PS: How about Vettes in the Village Oct 3rd? Call me if you get a chance. |
Thanks Doug,
I think I have everything I need. Thanks for the WD-40 reminder too. I can't make the October 3rd event, I have a conflict with my grandson's birthday party 2 hrs south of here. I'll call you later this week or early next week. John ![]() |
#9 | |
One issue (my own stupidity) is I forgot to install the original 4 bolts for the rear license plate and got hit with a full deduct. Second issue is the Center High Level Brake Light where I was hit with a deduction due to an error in the NCRS manual. But now I know about the manual error. Rest were small issues like paint chips, aging on items, etc. Considering the car has a little over 50K on the odo I am happy with the results. One more for the Top Flight list! Thanks to all! ![]() |
#10 | |
![]() Join Date: Sep 2009
