Old 06-16-2006   #7
tccrab
tccrab's Avatar
Default Re: Dreaded No Start fixed (hopefully...)
Sounds to me like a battery or battery cable problem.
When my No Start happened, jumping it did not make it start.
I'd bet dollars to donuts if you'd replace the battery and the cables the problem would go away.
Have you cleaned the battery terminals? A stiff wire brush is all you need, rough it up a little and knock off any corrosion.
Good luck!
TomC
'90ZR1 #792
