Old 01-29-2011   #1
mgbrv8
Default Re: Did the OBX headers fit or what???
The Tranny is in my drive shaft is rebuild, I started on some beam plates, and I removed the old factory headers(That was a BI#%CH). But I have not touched the OBX headers yet for a test fit, we have entered our heavy part of our autocross season and I have been swamped with my track cars repair and adjustments.
Dave
Old 01-30-2011   #2
carter200
carter200's Avatar
Dave,
I understand the delay with all you have going on. Another member has a set, too, so between you and him we'll get the scoop on the OBX header issue.
Get ready cause next week the real cold weather will be paying us a visit. Hang tough
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 01-30-2011   #3
mgbrv8
Originally Posted by carter200 View Post
Dave,
That's why I live in the southern tip of Texas all we ever have is sun and warmth in varying degrees. Its also the reason why I have so many projects . You never have too shovel sunshine.
Dave
Old 01-30-2011   #4
Dave,
What's real cold there? 30deg?
it was -4 here a couple weeks ago.
Old 01-30-2011   #5
carter200
carter200's Avatar
High of 17 is a bit much for central Texas.
When I was in Tech school in Chanute I can remember marching with a leather face mask to keep my face from freezing. Now that was a bit cool by Illinois standards.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 11-16-2011   #6
Blue Flame Restorations
I just bought a set of OBX's and I plan to have them Jet Hot coated.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 11-16-2011   #7
I installed a set of OBX, with WAZOO help, on a 94. I love them!
I had a chance to compare OBX to SW side by side. All tube bends are pretty much identical. Only difference is OBX collectors are about 10" forward and OBX comes w/ glasspacks that looks like metallic cats. These glass packs can be replaced w/ metallic cats if needed w/ minor mod. Cats should work better since being closer to exhaust ports should heat up better.
Quality is as good as any other headers I have seen.
Old 11-16-2011   #8
Did the dip stick tube need relocated for OBX?
Old 11-16-2011   #9
I assumed that it would since we used a relocation piece when we did the last install which was SW.
Yes - I used a relocation bracket and all went smoothly. Also used Stage 8 bolts.
By the way -do yourself a favor and get a set of gaskets from Jerry's. OBX gaskets are 8 rectangular individual pieces - one per port. Got to be a real PITA to use.
Old 01-30-2011   #10
Wow it gets that low in Texas? Neverwould have thought that
