Old 03-23-2011   #1
Captain A
Captain A's Avatar
Default Re: Update on my hi-miler Z project
Be careful about heat build up with the your amp.
Captain A is offline   Reply With Quote
Old 03-23-2011   #2
todesengel
+1
todesengel is offline   Reply With Quote
Old 03-23-2011   #3
Blue Flame Restorations
You give me inspiration to get my 88 done.
Great work and pics!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 03-25-2011   #4
VetteMed
Yep, well aware of that issue in that location. I've drilled many holes in the storage area lid, and will use spacers to keep the carpet elevated a little off of that area, to allow for airflow. I think that should be adequate. Thanks for the heads up though.
Old 04-07-2011   #5
VetteMed
Turns out this is very accurate - there's just not enough air space and airflow in the compartment, even with my modified storage compartment cover. I am going to relocate the amp to behind the driver's seat (I'm only 5'9" or so, plenty of room behind the seat).
Old 04-07-2011   #6
Andrew, this is just a shot in the dark so take it as a fwiw.
I remember reading about an issue that could develop at the trans tail seal if the T/Q on the beam bolts is over the specified value, and ( this is where my memory fails me ) if the C-beam is not centered correctly. Apparently bad alignment and or T/Q on the beam bolts distorts the tail housing causing a leak.
Okay, here goes my screw ball reasoning! If that can happen at the trans end of the beam, why can't it happen at the pinion end of the beam.
I do believe I read this in the Q & A section over at Bill's site, zfdoc.com.
http://zfdoc.com/
I wish I had better command of this subject to give you some better thoughts to help solve this issue.
Old 04-07-2011   #7
VetteMed
http://zfdoc.com/
Tom, that's a good thought. I am using the Beam Plates from Bill B., and I followed the FSM torque specs, so I don't know what else to try in the quest to do the job properly. I'll double-check my torque specs with a new torque wrench I just bought, next time around.
On another note, my Service Ride Control light came back on during the drive home from work today. Guess I didn't fully eradicate the gremlins. Gonna pull the codes in a few minutes.
Andrew
