04-11-2011 | #1 |
Chain rattle questions
I know the there is a new housing to fix the rattle, but what did GM do for Cars that this plagued? same thing (housing)?
I have not searched on my car but I don't hear any rattle at start up so that begs the question, would i here it? I just started my Z after sitting for a while (since nov) I was not in the car reached in with my hand (clutch switch is bypassed) so my head outside the cabin, I did not here the chain rattle. is it possible my 65K car has no rattle? I still need to locate the Pass chain tensioner housing..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 04-11-2011 at 08:12 AM. |
04-11-2011 | #2 |
Re: Chain rattle qeustions
sure it's possible. there's times my 90 doesn't rattle.
04-11-2011 | #3 | |
04-11-2011 | #4 |
can you tell by just looking if maybe you have the upgrade allready ? my 90 has almost 170 ,000 just started her after she sat for 3 months and she didnt rattle .i can t remember ever hearing either of my cars do it now that i think about it
04-11-2011 | #5 |
Would a pre-lube setup prevent this issue? I'm referring to the systems where you have the engine running and then close a valve thus trapping oil under pressure in a cylinder. Then when you are about to start the engine next time, you open the valve thus releasing pressurized oil into the engine. Once running, you close the valve, thus again storing pressurized oil.
Obviously quite bulky, but am wondering if this would help? peace Hog |
04-11-2011 | #6 |
This may not be related but when I bought my '92 back in '99 it had cam chain rattle on start up. After the second oil change of Mobil 1 the rattle has never happened.
04-11-2011 | #7 | |
04-11-2011 | #8 | |
I doubt it.
04-11-2011 | #9 | |
You would see the aluminum housing the new tensioner fits into. The ZFDOC may remember Brad. Hes seen your car a few times.
