Closed Thread
Old 06-28-2011   #11
VetteMed
Default Re: Motor mount swap questions
Andrew,
Now that the mounts are in have you noticed any less engine/drive train noise inside the car? I've beed wanting to do this for a while on mine as I get an unusual amount of drivetrain noise inside the car. I'm thinking the mounts are collapsed and there is metal to metal contact somewhere.
Did the header to steering shaft clearance get any better?
H
Hans, I just got the header gaskets in from Jerry yesterday, so I haven't been able to get everything buttoned back up yet. Also, I'm redoing the pinion seal on the rear diff yet again (maybe the third time will be the charm), so that's adding to the delay. I'll post up as soon as I get the chance to get things re-assembled!
Andrew
VetteMed is offline
Old 06-28-2011   #12
Andrew thanks for the tip. I ordered a couple of mounts from Rockauto. I figured while the block is being pulled what the hell. Daryll
GOLDCYLON is offline
Old 06-28-2011   #13
VetteMed
Yep, I wish I hadn't been so cheap when I had everything disassembled months ago. Makes sense to do it when they are easily accessible!
VetteMed is offline
Old 07-03-2011   #14
VetteMed
Andrew,
H
Hans, I drove the car today, I can't say I noticed any appreciable difference in the sound or vibration inside the car - but admittedly it's been over a month since I drove it so I'm not sure if it helped. It did NOT help with my header clearance issue, so I'm rather frustrated about that. My #1 primary tube is still just a hair away from the steering shaft. Perhaps I need to try to shim up the motor mount with some large washers to gain some clearance.
-Andrew
VetteMed is offline
Old 07-03-2011   #15
Ccmano
Good to know, I went ahead and ordered a pair from RockAuto as well. Good price too, paid $89 delivered. I figure if nothing else it's time they get changed out on my 21yr old car!
Let us know how the shimming goes. I have the same issue as you, the steering shaft is like 1mm away from the header pipe. Everytime I turn right I can hear the engine touching the shaft.
H
Ccmano is offline
Old 07-03-2011   #16
Hans,
Pull the motor and put some cams in there
LGAFF is offline
Old 07-03-2011   #17
Ccmano
Are you kidding, between the new job and the new house I barely have time to drive the thing. I have 3 Z projects lined up, parts are sitting here. This will make 4.
H
Ccmano is offline
Old 07-03-2011   #18
What are the three project?
LGAFF is offline
Old 07-03-2011   #19
Ccmano
Power coat the topend, the clear coat paint we used is yellowing (badly in some places).
Replace the shocks, found a set of original Bilsteins with only 200 miles on them.
Install the forced air intake I bought (like yours)
Now the engine mounts.
Thought about you yesterday, A buddy and I were checking out a 123K 91 Z for sale locally for $9995. He was thinking of getting it for his GF (he has a 94' with a Haibeck 415) Decent car, ran real good, but needed most of the usual C4 items repaired plus brakes and tires. Seller (used car dealer) wouldn't come off the price a dime. He passed.
H
Ccmano is offline
Old 07-05-2011   #20
VetteMed
Hans, an update for you... today I unbolted the lower nuts from the motor mounts, and jacked up the driver's side of the motor. I slipped 2 body/alignment shims in around the stud (I chose 1/8 inch each, for a total of 1/4 inch), and lowered the motor back down, and tightened the nuts once again. I gained approximately 3/16 to 1/4 inch of clearance between the #1 primary and the steering shaft.
I'd like to find a shim with a larger surface area, but I suppose this has got to be better than the interference that was present before.
VetteMed is offline
Closed Thread
