Old 07-10-2011   #1
Default Re: Thermostat question
I carry the Standt, my personal choice.
http://jerrysgaskets.com/store2/root...roducts_id=592
Gates makes one that appears to be correct, but I have not had it in my hand to confirm. Beware of all other brands, Failsafe, Duralast , etc.
Hi, Jerry,
I ordered a Standt 180 from Advanced Auto. I will check visually one it arrives. Do you think it's a good idea to drill a couple of 1/8" holes?
Old 07-10-2011   #2
Hi, Jerry,
I thought about doing a 160 Randy Woods thermostat, but ended up asking Pete to drill holes in my stock unit. Also installed a Ron Davis Radiator.
Wow it runs "cooler"!!!!!
Old 07-10-2011   #3
Hey,
Runs cooler at all times? How is it crawling in 90 plus day w/ ac on?
Old 07-10-2011   #4
Hey,
When "crawling" I don't test it, I turn the AC off.
Old 07-10-2011   #5
Woops! I forgot - it's a ninja turtle.
Old 07-18-2011   #6
I checked the part number on the 180 degree thermostat and per Stant website confirmed that it was for vin code "J".
Drained the coolant and with some reluctance removed three bolts (2 for housing and one to bracket). Reluctant because the last time I removed these bolts I ended up stripping threads (corrosion caused by different metal and coolant?) and had to have the car towed to a local Midas. They had it helicoiled and assembled so there was no way for me to know how well it was done.
Housing bolts came out easy enough but the bolt to the bracket was tough. May have stripped this one since it seemed to keep turning while being reassembled.
Any way, I did drill 4 x 3/32" holes before the install, filled w/ anti-freeze and topped off w/ distilled water.
I noticed coolant recovery bottle had greenish crustation. So, I took it off the car and tried to get the crud off w/ an end of a wooden cooking utencil but there was no way to clean upper inside. So, I went ahead and ordered a new one from Corvette Central.
Crusing into work it was about 78 degrees and water temp was between 192 to 203 depending on the traffic and rpm. Real test will be going home this afternoon since we are expecting 95 degrees or so and traffic for sure.
I figure in traffic with AC on she will probably climb up to 225 plus since the limiting factor I think is the air movement through the rad and AC condenser. Therefore, lower temp thermostat eventually will not make much difference but we shall see.
As expected, going from factory thermostat to 180 seems to have dropped the temp by 15 degrees as expected.
Old 07-18-2011   #7
Yun, which bolt? The top bolt that holds the bracket to the housing? Check that one as it may take a thread repair kit....I botched the initial threads on one of the other bolts that hold the housing halves together, and they are not blind holes so I just ran a tap thru and bought longer bolts. I think it was the bolt without the bracket....it was a few yrs ago so I don't remember exactly. I was thinking I was screwed, but when I looked & found that the holes were not blind I was relieved.
I'm almost positive the bracket to housing bolt is blind....you would think I'd remember, damn senility stinks!
