View Poll Results: Which oil filter do you use? | |||
AC Delco |
69 | 27.27% |
Amsoil |
1 | 0.40% |
Baldwin |
0 | 0% |
Bosch |
68 | 26.88% |
Fram |
13 | 5.14% |
K&N |
13 | 5.14% |
Mobil 1 |
54 | 21.34% |
Napa |
12 | 4.74% |
Penske |
0 | 0% |
Pennzoil |
1 | 0.40% |
PowerFlo |
1 | 0.40% |
ProLine |
0 | 0% |
Purolator |
3 | 1.19% |
Quaker State |
0 | 0% |
STP |
0 | 0% |
Wix |
18 | 7.11% |
Voters: 253. You may not vote on this poll |
Thread Tools | Display Modes |
#31 |
![]() Join Date: Jan 2004
On a related subject.... I see Mobil 1 is $21 a jug at Wallmart... not bad for 5 quarts.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
#32 | |
#33 |
YA BUT... You don't need a Mobil 1 filter... I use the Bosch... Autozone carries them.
BTW... Walmart is over $2 a quart cheaper for Mobil 1 oil than Autozone
#34 |
I read on Marc's site the Bosch drains thru the check valve after 24 hrs, so I'm gonna try the Wix from NAPA
#35 |
Thats new updated Marc info
#36 |
![]() Join Date: Feb 2011
The previous owner used Bosch and that's what I'm going to continue to use. No rattle from what I can tell, pressure comes up quickly, oil stays clean.
I've only owned the car for about two months so my opinion doesn't really matter. ![]() |
#37 |
![]() Join Date: Jul 2005
I will be switching from the Bosch to the WIX (NAPA) per Marc's new recommendation.....
#38 |
![]() Join Date: May 2005
I've been using the Bosch for several years, but I've noticed more chain rattle with the last 2-3 ... Marc's new info just confirms this. Makes me wonder if Bosch has "changed" their filters. Shame, I liked the look of the Bosch with the label removed. I will be trying alternatives soon ... may even change to another filter in the next few days even tho I changed oil/filter a couple of weeks ago. This last Bosch filter has more chain rattle than any filter I've used.
George |
#39 |
![]() Join Date: Jan 2009
Mine is not even shown. Valvoline oil filt.
But I also have some Frams.
#40 |
I use Mobil 1 Extended performance and the Mobil 1 Filter that goes with it. No chain rattle or weird oil pressure readings on my 54000 mile LT5. I get it all at advance auto parts which normally does a deal on the mobil1 which gives you 5 quarts and a filter. I buy two kits each time and have some extra filters. Each time I also have an extra quart, so pretty soon I'll have enough quarts and filters to do it for nothing, sort of.
