Old 09-27-2011   #1
mike100
Default Re: how do you clear
It sets if you start the engine 3 times without any VSS signal to the FX3 controller. you could pull the battery lead if you don't have a tech1 scanner to clear it for you.
if you have a good speed signal to the fx3- it should work, otherwise maybe you will have to replace the shock computer (or at least see if the speed signal makes it to it).
Old 09-27-2011   #2
a1991zr1
which battery lead dont quite understand i have a snapon scanner obd1 but all i can see is ecm and ccm please advise
a1991zr1 is offline   Reply With Quote
Old 09-28-2011   #3
mike100
just pull the ground cable off of your battery. That resets everything...including the clock and radio presets (unfortunately).
The FX3 control is independent of the BCM or the engine ecm. It doesn't have high level diagnostics or serial data- just a pin that gets grounded that flashes the light on the display for the selective ride. The factory tech1a can clear it, but if you get a spee signal to it, it should clear itself.
Old 09-28-2011   #4
a1991zr1
disconnected battery for 30 minutes no luck now what
