Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 10-30-2011   #1
ZONER 95
Default Windshield Question....
I'm curious what the NCRS stand is on our ZR's windshields.......do they deduct for original with delamination?.....what about a replaced windshield?......which senario is deducted more....a bad delam or a new replacement?....
ZONER 95 is offline   Reply With Quote
Old 10-30-2011   #2
ZONER 95
Default Re: Windshield Question....
Another question.....if you have the dual roof option do you need to bring both roofs for judging?
Old 10-30-2011   #3
vettn71
An OEM replacement windshield like a (non-ZR) would get a 50% deduction, I believe on originality points as a service relacement. Then you've got date codes and the like to deal with. You would get all the condition points. An original windshield that has delamination would get all the originality points, but would get deduted for condition. Unless it was considered dangerous you would be better staying with the original. If you have a judging manual ity goes through the standard points deductions
vettn71 is offline   Reply With Quote
Old 10-30-2011   #4
delamination will get you a deduction on condition. the replacement will get you a deduction on originality, date stamps, blah blah blah
yes you need to bring both roofs and everything else that came with the car
Old 10-30-2011   #5
you will also need to get rid of the radar detector, the thing in the cup holder and the key switch in the console
Old 10-30-2011   #6
ZONER 95
Yeah, I figured that....I'll pick up the NCRS lit on the subject....may consider having the car judged before replacing the original tires.
Old 10-30-2011   #7
tom barr...barrhere i think his SN is here, is big into the ncrs stuff
Old 10-31-2011   #8
jrd1990zr1
jrd1990zr1's Avatar
For the 1990-91 MY, NCRS uses 26 points for originality and 24 points for condition. Assuming your MY has similar points (I can check for you if needed).
If you kept the original windshield I would give you the 26 originality points and depending on the amount of area of delamination would prorate the 24 points.
As far as a service replacement I am not sure there is a standard deduction for a proper service replacement windsield for a ZR1, so I would need to check.
In my opinion unless the delamination effects the entire windshield and you can not see throught it causing a dangerous condition I would have it judged as is.
My $0.02
BTW: Tom Barr is the NCRS national team leader for our cars and would be able to provide better clarification on this issue and others.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 10-31-2011   #9
it should be noted the standard c4 windshield is not the correct replacement
Old 10-31-2011   #10
ZONER 95
This car has a replacement windshield from original owner due to bad delamination.....it now has a PPG Sunshade Solargreen Duplate....Is that considered the correct replacement?...
