Old 03-10-2012   #11
Default Re: Next! Top End Touchup
Well the touch up has turned out to be just a bit more. Most of the I/H ports needed help as far as getting a consistent 36mm dia. Now the ball rolls through each port. The pass side needed more work than D/S. The plenum won't need any further tweaking other than smoothing the runner walls. Should be interesting to see what additional airflow does w current tune. Oh and just to show I was pushing it, I have 2 ports with pinholes.
HEY AL!
Old 03-10-2012   #12
ALZR1
pin holes huh,how thin did you get the surrounding area and when are you coming over?
i hope the pin holes are in the Plenum or the injector housing.
AL.
ALZR1 is offline   Reply With Quote
Old 03-10-2012   #13
Al,,
Overall not bad although a larger area on D/S needs help. It's the primary runner and the front bolt hole wall. See you this week.
Old 03-11-2012   #14
HEY AL!
I wonder how many hp you'll give up by plugging those pinholes! Still hoping you see at least 450 at the wheels before the top end is "finished".
P.
Old 03-11-2012   #15
No pinholes = not enough porting. Go on and rip them up Dom.
Old 03-11-2012   #16
Marc says, "If you don't punch through at least once, you aren't trying hard enough!"
P.
Old 03-11-2012   #17
P.
Al creates airfoils from his repairs so he gets more flow.
Old 03-11-2012   #18
I will say when Al does them you cannot tell someone has been there....
Old 03-11-2012   #19
Finished port touch up. Here some pics. I am going to guess there'll be an increase in air flow. I'll probably take these to get stripped
and then to Al for any repairs. The media blasting will help uncover any other weak areas or pin holes.
Old 03-11-2012   #20
BTW, piinhole count is now up to 3.
