#11 |
![]() Just unplug but yeah its no longer needed. Cleans up a lot of room in the engine compartment
#12 |
![]() Join Date: Nov 2011
Thanks GC, I'll keep the post up to date.
#13 |
![]() Join Date: Feb 2011
It is true, the factory only used 7 or 8 fasteners on the original manifolds.
#14 |
![]() Join Date: Aug 2006
#15 |
![]() Join Date: Dec 2004
Steve, you may want to check me on this but I do believe that with headers you will be a bit lean with the OEM fuel programming. Check Marc's web site as I think he has details on the page with all the EPROM descriptions and prices.
I know back in the old days a sbc 327 or 350 would run waaay lean on the back two cylinders on each bank with headers & stock jetting. It was sort of commonly accepted procedure that you had to step up the primaries 2 steps and the secondaries 3 steps just to start with and read plugs from there. ![]() ![]() Tom
#16 |
Thanks Tom. Just heard it run, sounds great, looks great, and the installer was happy with it. If he doesn't take all my money, I may go straight to Marc for a chip.
#17 |
See if somebody has a used one here for sale first. Just an idea ...... You never know
#18 |
You want/need Marc's chip for several reasons, no buyer remorse
#19 |
There is a rather large plug on the back of the air pump. I pulled it. Was that the right thing to do?
Just e-mailed Marc for a chip. Looks like I'll wait 'till BG, he's advertising 10% off and he'll install at BG. Sounds good to me. ![]() |
#20 |
About the air system, do you just disconnect the pump and the switch/valve at the top of the wheel arch, and reroute the vacuum line? because that is just what I have done on my new toy! Does this give you a failure code?
My motor was running quite rich when I drove the car home after buying it, have since replaced both O2 sensors because they didnt work and have now removed the air system, as sugested else where. Unfortunately I cant go for a ride as Im waiting for a gearbox rear seal. ![]() |
