Old 07-01-2012   #2
vilant
Default Re: Service Ride Control Light
Have the original owner's manual and I am quoting from it. "When you start the car, this light should come on briefly to let you know it's working. You should have the light fixed if it doesn't come on, or you won't know if there's a problem w/ the system.It's normal for the Service Ride Control light to stay on if you've turned the ignition from "OFF" or "Lock" to ""Run" three times without moving the car. The light should go out once you drive the car. If the light stays on when you move the car or comes on while your driving, there is a problem with the system. You can still drive your Corvette, but have your Chevy dealer check the Selective Ride Control System as soon as you can." Hope that helps.
