Old 09-11-2012   #21
Default Re: Raptor and Henderson Performance
Ron,
BTW, I am in Vegas this week, leaving Thursday am. staying at The Paris for conference. Let me know if you can come over for a drink.
Dominic
Old 09-11-2012   #22
tf95ZR1
tf95ZR1's Avatar
Ron,
Dominic
Dom, I think he's in Dubai or somewhere exotic like that.
Wow, I know the whereabouts of forum members better
than that of my own kids!
Old 09-12-2012   #23
RHanselman
RHanselman's Avatar
Yep, Dubai...
Scheduled to be back on the 27th...
Old 09-12-2012   #24
RICKYRJ1
RICKYRJ1's Avatar
Originally Posted by RHanselman View Post
Twin...
$10k for the base system.
I also have 18 LT1 Single Turbo systems. I'm going to mod one and then test it on both of my Ruby's. It may be perfect for a stock Z...
Cheers,
RH
What does the base system consist of? then also what would be above that if at all? 10k doesnt seem bad for that much power being added and assuming a safe reliable tune. what are you thinking HP #'s on the single set up? Hope this all works out for all parties envolved, it makes a great addition/option to our cars
Old 09-12-2012   #25
A1990
A1990's Avatar
I would be that to be a low boost $$$$. You will need to redo your bottom end and lower the compression and while your in there...etc, etc. etc...
Not sure if the $10k includes labor of any kind...
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 09-12-2012   #26
RHanselman
RHanselman's Avatar
Off the top of my head...
The base system contains:
Stainless Steal Hot and cold pipes (CATs if needed)
Turbo's
Turbo Oiling system
Waste Gate
Blow-Off valve
Electric Harness
Hardware for the above
Options:
Intercooler
Exhaust Tips
Gages
Fuel Pump
Injectors
Raptor ECM
Headers
Right now, only option is to have Corey Henderson install the system. I think Ron said Corey is charging $1700 for the install but I could be a little off... I'll check again
The Single Turbo on a stock car should be around the same HP/TQ numbers as the stock dyno sheet above. Those numbers are from my stock 91 with twins pushing around 4 psi. All for around $5500...
Old 09-12-2012   #27
RHanselman
RHanselman's Avatar
Yes, low boost. We think the max boost for a stock engine with the stock ECM should be no more than 5 psi. I believe Mat's car (single turbo on a stock engine) was running 6-8 psi and was getting 550HP but he eventually lost a head gasket. You'll have to ask him the specifics...
$10k does not include labor.
FYI - I'm using the stock crank and rods on my 374. The engine builder said the stock internals would good to 1000 HP. He did however perform some lightening and stress relieving on the rods. I believe all the engine work and parts for my 374 cost around $9500 even with Ron Woods Head Studs. The goal is to eventually up it to 15 psi...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 09-13-2012   #28
Locobob
Arrrgggg! Really wish I had the money to do this, working and going to school part time isn't leaving me any extra cash to play with. I just love the sound of whooshing turbos!
Robert
Old 09-15-2012   #29
RHanselman
RHanselman's Avatar
I'm sure we can work out a Lay away plan... ;-)
Old 09-15-2012   #30
USAFPILOT
USAFPILOT's Avatar
law away sounds good...just lay the turbos in my trunk and I will pay you in a couple years.
