#11 |
I have stock Z06 18/19" wheels. The fronts are 40mm offset but the rotor offset will make that work. I'll show a before and after in terms of fender fit and clearance.
#12 |
The Z calipers needed a bit of modding in order for the adapters to fit. No biggie.
Also a couple of pics showing the size of the brakes relative to the fender opening. These things are pretty big. ![]() ![]() ![]() ![]() |
#13 |
Question?
Will I need to bleed ALL the brakes or just the fronts? |
#14 |
![]() Join Date: Sep 2011
Get some speed bleeders .It only takes a second to bleed them and a good idea to keep the fluid fresh anyway.
Those Calipers are huge! Nice! |
#15 |
Interestingly, each side has its own bleeder.
#16 |
Now thats a big brake setup! GC
#17 |
Looks like I need to "shim" the caliper in order to center the rotor in the caliper.
Haven't checked passenger side yet. |
#18 |
Here's a pic of the difference in offset for the Brembo and Z06 rotors. Pretty significant which should make the Z06 wheel tuck in nicely. You can also note the difference in thickness.
#19 |
I would definatley bleed the entire system. Start with he right rear, left rear, right front, left front. ATE fluid is not a bad choice. It is inexpensive works well. I have used it in my race car for years. I would suggest the gold color rather than the blue. It is easier to tell if it is dirty with the gold. Hope you like the brakes. Congrats!
#20 |
![]() Join Date: Jul 2007
next you will want the 4 piston Z06 brakes for the rear
