Old 10-06-2012   #1
Ronstar
Default Coolant leak
Coolant leak passenger side front..ideas?
Ronstar is offline   Reply With Quote
Old 10-06-2012   #2
Default Re: Coolant leak
Where? Pump?
Old 10-06-2012   #3
ideas....hum...fix it?
not giving us much to work with here
Old 10-06-2012   #4
Captain A
Captain A's Avatar
check radiator/overflow hose connection to radiator/ lower radiator hose. how many miles on radiator?
Captain A is offline   Reply With Quote
Old 10-07-2012   #5
Ronstar
Fix it?... Hmmmm that's a great idea!!(kidding).
That's the plan can't tell much from top or underneath
Dripping off front crossmember. Just being lazy thought
There might be a likely culprit. Water pump and radiator
Are both fairly new.
Old 10-07-2012   #6
scottfab
scottfab's Avatar
Run the car hard. Get the temp way up.
Jack up and look.
Using just a pressure injection cap does not always
work if the leak is on the downhill side of the thermostat.
Sure hope it's not your water pump again.
Scott
Old 10-07-2012   #7
batchman
When cold, put a finger on the bottoms of the hose junctions. I predict one will be wet.
- Jeff
Old 10-08-2012   #8
tf95ZR1
tf95ZR1's Avatar
I just had to replace my radiator, ~70K miles.
The plastic passenger side tank had separated
from the aluminum cooling stack. Saw rust all
over the affected area, and a puddle on the floor.
About $100 for an OEM replacement good for most
situations, up to $600 for a thicker radiator.
Lets "discuss" again whether any modifications are
necessary for a Fluidyne "drop in" radiator....
tf95ZR1 is online now   Reply With Quote
Old 10-08-2012   #9
Hammer
Hammer's Avatar
Talking Re: Coolant leak
Get a pressure tester from your local auto parts store. OReilly, Autozone and others rent them. Pump the system up to about 15 lbs, guaranteed to find the leak.
Old 10-08-2012   #10
Make sure bolts are tight on waterpump
