#1 | |
![]() Join Date: Nov 2007
Your're correct, far as the 90s go. They were sans seals on the exhaust valves - per Lotus Engineering felt those valves needed extra lubrication (ref: Heart of the Beast?). I've also read where the particluar open deck architecture employed in the LT5 is prone to some oil consuption, as a result of the top of the sleeves anchored to the head via friction. Sleeve lenght uniformity is absolutely critical to oil consumption, and tollerances being tollerances, and vibrations and stress being what it is (read: sleeve instability), sleeve stability contributes to oil consumption. ![]() Marc's caging the sleeves in his BIG inch builds seems to be addressing at least some of the oil consumption (have to ask 'im or Frank U) by stabilizing the sleeves (reducing the dependance on friction against the head for stability). I've not heard yet if AES' closed deck design is effective in reducing oil consumption, but clearly that design stabilizes the sleeves as well. ![]() (Maybe someone with REAL expertise could chime in? ![]() Comments about "first quart" consumption was news to me. And too can you or anyone tell me if the hashed segment on the dip stick represents a quart or is it something less? I put in a quart when the level was just below the hash, and checked it the next day. The level now as above the hash (full) line by an equal amount....WTF? I'm wondering if the seal on the dipstick caught on the edge of the tube and maybe didn't allow a proper sounding of the oil level. Have you (or anyone else) ever noticed that?? From the way I drive (spirited ... Hey, living in the country has its advantages! ![]() Gotta run! P. |
#2 | |
![]() Join Date: Jan 2009
#3 | |
Yep Concur the MY 90 had no seals for the exhaust valves. That started MY 91. However, before I replaced my motor it always burned through the first quart real fast. Another question if I may does anybody see a lot of black soot/carbonation on their rear fasica from there exhaust like I used too? GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 10-23-2012 at 01:49 PM. |
#4 | |
Otherwise I get the two spots on the driveway just outside the door.
Yep I can relate to that happened. Pre engine exchange that was a daily occurance
![]() ![]() Join Date: Feb 2010
In reference to getting a more accurate oil level reading. I like to check my oil before I fire up the car in the morning, when checking. It's trivial, but it does make sense to use this method when possible.
Well I topped off my oil early this morning and just checked it.
It does go above the fill mark by about 1/8th in. BTW I go through a lot less oil if I keep it at the add mark and not the fill mark.
#8 | |
Interesting topic. P. |
