![]() Join Date: Dec 2003
DAW THIS ON THE NET SERV AND THOUGHT IT WOULD MAKE AN INTERESTING THREAD FOR COMMENTS HERE---WHAT DO YOU THINK/KNOW ABT THIS ISSUE???
Has Anyone read up on the effects that the removal of Zinc Phosphate from oil is having on engines. We had a speaker at my local corvette club (Corvette Club of Delaware Valley) meeting speaking about this. Evidently the federal government has mandated the zinc removal and it is causing engine problems. This particular gentleman was running diesel truck oil in his cars in 2006 because it still had it but is being removed per mandate in 2007. He is now running Comp Cam break-in additive (has Zinc)in his oil. He has older Corvettes and various other cars (Ferrari's, etc.) so Synthetic oil is not involved. Is anyone familiar with this and what about synthetic (Mobil 1)?? This is from memory so it is a bit vague. A year or so ago there was a thread here that discussed this topic related specifically to Mobil 1's New 'Advanced' formula (zinc eliminated). The discussion at that time indicated that some people (as I recall Hib offered some insight at the time) were using Mobil 1 motorcycle specification oil which was supposed to retain the zinc at that time. Also it was mentioned that Mobil 1, 15-50 weight oil retained the zinc phosphate additive . I use Mobil 1 combined 15-50 with 10-30 weight which seems to help with start up chain rattle and purchased a large quantity of the "old" formula 15-50 to benefit from the zinc content. (Mixed weight oil is a personal decision, not OEM supported and subject to debate among members of this list. This is not a recommendation). There was good information in that thread and you may benefit from an archive search or recollections from some that have a better memory. John R Sullivan '91 Polo Saddle #283 Original owner. My understanding from this discussion is zinc is no longer in the Motorcycle oil and we all should be looking for a suitable replacement. I will check out the archive. I must have missed that thread I found this information - I think it was also mentioned in a relatively recent issue of either Vette or Corvette fever. It seems to talk mostly about older flat-tappet engines. "...reduce the amount of ZDDP (zinc dialkyl dithiophosphate) in street-legal, gasoline-engine motor oils. After all, they weren't needed with modern roller lifters and overhead-cam followers. The reduction first started in the mid-'80s, and it has been a gradual process, but the latest API SM and GF-4 specs have reduced ZDDP content to such an extent that the new oils may not provide adequate protection for older, flat-tappet-equipped vehicles running nonstock, performance cams and valvetrains. http://www.hotrod.com/techarticles/e...ech/index.html SO DOES IT MEAN WE DO NOT HAVE TO WORRY ABT THIS ISSUE IN THE LT-5??? OR DO WE??? MY GUESS IS WE DO NOT SINCE WE DO NOT HAVE FLAT TOP ROCKERS??? |
![]() Join Date: Mar 2004
Was reading the same emails last night and had the same thoughts. When was ZDDP removed from Mobile 1? Is there a ZDDP stand alone additive available? Will the addition of ZDDP be bad for our cats? I'm just full of questions this morning.
![]() Join Date: Jul 2004
Hi
I was one of the posters on the maillist, I also found this article on additives and ZDDP - http://www.performancemotoroil.com/t...additives.html which also suggests it's not such a big deal perhaps. For example: "The zinc in your oil comes into play only when there is actual metal-to-metal con tact within your engine, which should never occur under normal operating conditions" So presumably as long as you're not starving the oil from parts of your engine, it should be okay. It seems unlikely to me that oil companies would make changes that would end up causing damage to customers engines. I know we're talking about 'high performance' engines here, but I would imagine that your typical oriental 'buzz bomb' isn't too dissimilar in terms of loads per component. Internet scare perhaps?
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#4 | |
#5 | |
street-legal, gasoline-engine motor oils. After all, they weren't needed with modern roller lifters and overhead-cam followers..." The government can obviously mandate anything they can get away with, but I doubt that the oil companies (and their huge lobbying groups) would go along with it if they were opening themselves up to who know's what lawsuits by deliberately creating a product that will knowingly damage what is bound to be a large number of engines? It just seems to me to have the hallmarks of internet hysteria - a couple of guys do engine builds, dont use the right assembly lube and screw their engines up. Of course they could never make a mistake so they find a convenient scapegoat. You know how it goes. Has anyone any first hand experience or attributable data on damage caused by this? I have a completely open mind - but rumours posted on the internet aren't evidence.
![]() Join Date: Sep 2005
Interesting topic
#8 | |
Yes that was my way of starting the debate and quest for the answer. Are we flat-do we need need to worry? ![]() |
#9 | |
#10 |
What about "Royal Purple" does it have this Zink in it? Does anyone use Royal Purple?
