Just have ta show some of our In-House Talent........(Carter and Lee)
Carter200 Bling All Aluminum Caps are machined with very close tolerance and fit perfectly over existing caps. All Aluminum caps are engraved as follows and as shown for the Brake Fluid Aluminum Caps. 1. POWER STEERING FLUID (Steering Wheel Etched) 2. RADIATOR 15 PSI CAP 3. WASHER FLUID ONLY (Wipers Etched) 4. ENGINE COOLANT OVERFLOW 5. BRAKE FLUID DOT 4 ONLY
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by ZBrink; 01-24-2025 at 09:22 PM. |
I see lots o Bling
Wow Now that's alot of blingo!!!!!!!!!!!!111
Sweet!!!!! ![]() David |
![]() Join Date: Dec 2004
![]() ![]() ![]() ![]() Tom
#5 | |
![]() Join Date: Jun 2004
![]() PS: No flat spring required
Hi All:
Great Thread! Any sources on replacement aluminum tanks for the various plastic tanks underhood? |
![]() Join Date: Dec 2005
I also sport Carter hardware but I pc'd them black and colored in the writing with a silver/red combo. My Coplon is also painted black. Always get big compliments directed at Carters work.
Cliff,
Thanks for the kind words. I have the billet throttle body plates in stock right now and soon I'll have your order finished. Yank those coolant pipes off and let's bling em' up............. ![]()
#9 | |
![]() I am going to experiment with highlighting the various billet covers etching with Red when I figure out the best way to do that. The Etching on all the fluid caps and especially the Oil Filter Cover was perfect. The AMSOIL on top edge with ZR-1 in the middle and 10W 40 on bottom edge was excellent ![]() If you have the billet TB plates in stock, PM me for a price and we can add that to the present batch. I want to powder coat the 90' LT5 Cam Covers, Plenum and coolant pipes before I send them your way ![]() Cliff
#10 | |
Yes, I prefer the coolant pipes be done first before I engrave them. The job turns out some much sweeter. PMing you now...... ![]()
