Old 01-19-2013   #1
Schrade
Default Anyone familiar with TCI handheld controllers for auto?
I cannot program the settings in any way (Setup Wizard, for default settings, Advanced Options, etc.).
If you're at all familiar with this controller, please have a look at this post in TCI Product Support Forum
http://www.cpgnation.com/forum/contr...10-a-8065.html
I haven't traced the controller module wiring yet.
If out-linking is verboten, sorry - wipe it, if out of order.
Thanks here...
Old 01-19-2013   #2
vilant
Default Re: Anyone familiar with TCI handheld controllers for auto?
What is the controller actually supposed to do?
Old 01-19-2013   #3
Schrade
Changes TC lock up RPM, shift points low (and high) by TPS, shift engagement firmness, etc...
Setup Wizard bases operation on tire size, rear end gearing, does a TPS calibration for range, etc.
I had a vid of live data read, but the handheld screen doesn't show...
Old 01-19-2013   #4
vilant
I see, well I've never had any experience w/ it, sorry. Hasn't "support" for the product gotten back to you.
Old 01-20-2013   #5
WVZR-1
Thanks here...
Chuck,
I've sent you a link for the install and documentation!
Old 01-20-2013   #6
Pete
Pete's Avatar
If your getting comm error,i have found the 3 wires at the controller plug are crossed.i can't remember which one is wrong,i will have to look at the local auto Z's plug.
I will have to get back to you with this info.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-20-2013   #7
Schrade
Got the link (and saved) Dave; that's my control module -
Pete - I have begun the wiring trace, and found some crappy connections at a newly found device 'Dakota Digital SGI-5 C'. . I told those hacks that I wanted to COMPLETELY ANNOTATE MY FSM, and they won't give ANY RECEIPTS, PAPERWORK< OR SQUAT.
Anyway, this is what I found...
I'm hoping this is the source of the Comm Error, but I know that I HAVE TO trace all lines...
AND THANKS FOR THE FLEXPLATE TOO THERE, PETE!!!
Old 01-20-2013   #8
Schrade,
Looks like real quality work. NOT! Is that supposed to provide a VSS signal?
Old 01-20-2013   #9
WVZR-1
I would have thought the Dakota Digital could have been avoided. Those devices can raise hell with most of the things that are troubling you. I believe the cruise is difficult to accomplish and who knows whatever else.
I guess it's sort one device at a time!
When I looked at the transmission controller it seemed pretty straight forward and I believe I understood it, I understand what it would have taken for the VSS to function as intentioned also.
Old 01-20-2013   #10
Yep. That's what it is.
http://www.dakotadigital.com/pdf/sgi-5c.pdf
Can't tell by pic but it looks like there's no sensor ground.
