#29 | |
Your lights don't go through the board. Only way to check the missing incandescant bulbs is to pull them, and check the bulb filament for continuity, then check the Incand input (the solid gray input on the smaller HU connector), TO the first bulb socket, then the second (I don't know if the bulbs are in series, or in parallel). ON SECOND THOUGHT; THE FSM NOTE TO THE RIGHT SAYS NOT TO MEASURE IMPEDANCE TO THE UNIT - I DON'T KNOW IF YOU CAN ISOLATE THE INCAND CIRCUIT THROUGH THE HU (in the 2 schematics, board header ID's P701 and P702 correspond to CN101, and CN102, respectively, to our HU header ID's. Never mind my notes there; that's for the AUX Input mod... The gray input ![]() ![]() Last edited by Schrade; 02-25-2013 at 03:07 PM. |
