#11 |
![]() Join Date: Mar 2007
Connected the clutch wires......replaced what I think was the starter relay....did not seem to jive with the diagram, but the wires were yellow/blck and connected to thec clutch switch....so I think I have it right
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 06-02-2013 at 12:50 PM. |
#12 |
The yellow stripped black wire is for the starter relay,thats the ground I believe.
#13 |
#14 |
#15 |
The starter relay is the one closest to the column,I think.I pulled the relay and tried to start the car just to make sure.The yellow stripped black wire should be the relay ground,the 14-16 gage wire with the non factory blue splice connector on it.
#16 |
Its hard to make out anything in these pictures but this is the splice I made for the new ground,I ran a 10 gage ground wire from the splice to a stud coming off of the dash support.[IMG]
#17 | |||
![]() Join Date: Jan 2009
Thing about the clutch switch on the early cars is you never want to turn the key before fully depressing the clutch peddle. The contacts can handle the current just fine IF the switch is engaged. Problems happens when the key is turned first and the then the peddle pushed (or at the same time). The switch gets arced in this case. Too many times arcing the switch damages them. I had a problem in 97 but none since then.
#18 |
I almost think its the battery also, it was made 6/2012 and installed this year. They did a load test yesterday and its fine.
We will find out
#19 |
Scott by volatage drop I am referring to the fact that when you turn the key volts drop on the dash
#20 | |
![]() Join Date: May 2005
yler |
